Home › Forums › General Discussion › GPS in bright sunlight
- This topic has 7 replies, 8 voices, and was last updated 10 years, 10 months ago by
davearoy.
April 30, 2015 at 9:13 am #235700
I have two GPS’es. An older Garmin and a 3 YO Tom Tom.
Neither has a display that is bright enough for me to read on a top down sunny day ride. If any of you has one that might work, I’d appreciate the info.
…and NO, I do not have a smart phone – it’s dumber than a rock.
Thanks!April 30, 2015 at 10:10 am #264292Justt keep driving.
You’ll find out where you are when you get there! 😎ÂWhich is another way of saying I have no idea.
ÂPaul Mossberg
April 30, 2015 at 10:43 am #264293You may want to to try something like this:
http://www.amazon.com/s/ref=bl_sr_gps?ie=UTF8&field-brandtextbin=Glarestomper&node=172526
Slowly coming back from the ashes...April 30, 2015 at 12:00 pm #264294Roy,
I made one for my last couple of trips out of thin cardboard and black electrical tape that looked very much like the pictures Kent posted. Did not know you could buy – or maybe I am cheap.April 30, 2015 at 2:16 pm #264295How about mounting under the dash? Should be well shaded, and gps signals go through fiberglass, no?
April 30, 2015 at 6:19 pm #264296I haven’t used a GPS in a long time, but I do have some of those commercial shades such as those in the Amazon link. They work well enough, unless the sun is at your back and directly on the screen. I partially solved the problem in my Honda S2000 but using a mounting bracket near the top of the transmission tunnel.
April 30, 2015 at 6:41 pm #264297I mounted mine on the tunnel ahead of the gear shift worked fine .
May 1, 2015 at 2:24 am #264298I made mine out of a cardboard cereal box, and painted it black. I did not know of the pre made ones
Dave
Dave
Lakeland, Florida, where we drive Topless every day -
