Home › Forums › General Discussion › H4 Headlights
- This topic has 6 replies, 5 voices, and was last updated 13 years, 7 months ago by
Mike.
August 8, 2012 at 11:35 am #234250
I’ve been noticing a lot of articles about the H4 healights in VW magazines. They are supossedly considerably brighter than our stock headlights. I’m not planning on doing a lot of night driving but seeing at night is a good thing and it sounds as if these H4 headlights would improve our night driving visibility. I know EMPI makes the H4 headlights for the 12V Beetles but has anyone seen or does anyone know if someone makes them for our size headlights? Also, wattage considerations are not a problem. Does anyone know of any other concerns that would applu to our TDs? Thanks for your input.
"If one thing matters, everything matters" - from the book The ShackAugust 8, 2012 at 4:20 pm #251341Your MG should use the standard 7″ hi/low sealed beam.
The Empi H4 Headlight Conversions are 7″ “shells” that fit the same space as the old sealed beam.Everything I’ve read says you just install ’em in place of your sealed beams.Not sure if that is accurate.Paul Mossberg
August 8, 2012 at 6:58 pm #251342If your pockets are really deep, opt for the 7″ LED headlamps.
List Price is over $400 each.
You should be able to find them for less than $300.Bill Ascheman
"Drive Happy"August 8, 2012 at 8:15 pm #251343Are those those carn-sarned BLUE buggers that blind me on the highway? ’cause I do hate those.
August 9, 2012 at 4:24 pm #251344No Sir,
Bright White.When I got the bulletin on them, I was going to order them for minebut when I saw the price…No way !Bill Ascheman
"Drive Happy"August 9, 2012 at 8:08 pm #251345On those few occasions when I find myself out after dark I’m happy to have any headlights at all. When they work, mine seem to work fine.
August 10, 2012 at 2:27 pm #251346When I installed the headlight relays in my car I replaced the 6014s with H6024s.After the relay install I compared brightness between the two by only installing one of each and the H6024s were much better.I think just the relay install will make a lot of improvement in most cars.The stock 6014 is 60/50 watts high/low beam.
The H6024 halogen is 65/35 watts high/low beam -
