Home › Forums › General Discussion › How to Use Side Curtains
- This topic has 9 replies, 6 voices, and was last updated 11 years, 8 months ago by
July 10, 2014 at 12:48 pm #235240
I have a ’83 Daytona MGTD replica. I use the side curtains only when she’s parked outside in rainy conditions. As I was putting them on this morning (possible showers) I noticed the zippers had pull tabs inside and out, implying they could be zipped from the inside. I thought about it and thought if I snapped the buttons along the door and got in I should be able to zip the window up but that would leave some snap undone along the aft end of the curtain. Any suggestions?
July 10, 2014 at 2:54 pm #260689Classic Roadsters Litd. side curtains have an additional zipper under teh side window. You can open that, reach through and attach the curtain to the windshield frame (and pay tolls in the days before EZ-Pass).Without that additional access zipper … attach all the snaps on the door at at the rear of the curtain. Start the zipper (which I hope zips from rear to front). Let the curtain fold down on itself. Get in and finish zipping the curtain to the roof. Then use one of these tools to snap the curtain to the windshield frame:
You can also attach the curtain everywhere except the door, including zipping the curtain to the roof. You’d get into the car by doing the limbo under the curtain. Not elegant, but it works (and I have done it!). Then use the tool above to attach the curtain to the door snaps. This might be easier as there is probably less tension at those snaps than at the windshield frame.PMOSSBERG2014-07-10 15:00:11
July 10, 2014 at 3:45 pm #260690The “Top-Snapper” Canvas Snap Tool is available from Amazon for $18.95.
BDriverJuly 10, 2014 at 3:55 pm #260691Thanks bdriver. Appreciate the help!
I didn’t do much searching. Just wanted something to show.PMOSSBERG2014-07-10 15:55:12
July 10, 2014 at 5:18 pm #260692Please allow me to add to Paul’s instructions.
I removed the set screws on the slide that tensions the bows, and replaced with small knobs from Tractor Supply. Puta dull point on the screws and then you can, without an Allen, loosen the bows. This makes erecting and putting side curtains in much easier – at least on mine.Royal2014-07-10 17:19:12
July 10, 2014 at 6:53 pm #260693Paul,
It was a good find.I bought one. It will pay for itself the first time I don’t tear a snap.BDriverJuly 10, 2014 at 9:16 pm #260694I found that the best way to use the side curtains is to keep them wrapped up in a bungee cord in a plastic garbage on a shelf in your shop .
July 11, 2014 at 6:11 am #260695I purchased that snap tool on Royal’s advice last year and was surprised how much easier it was to fasten the snaps. It’s well worth the money.
"Drive Happy"July 17, 2014 at 11:51 am #260696The Top-Snapper arrived. The directions show you how to open and close snaps from inside and outside. The designer thought about the problems this tool solves. There is a thin part of the blade that will catch the inside of a snap and enable you to pull it closed from inside the car.
The instructions are in two languages. The second is French.July 17, 2014 at 1:57 pm #260697Yup! Glad it’s working for you!
Alomst as good as electric windows! 🙂Paul Mossberg
