Home › Forums › Site › Rules and Etiquette › Introduction — follow up
- This topic has 13 replies, 7 voices, and was last updated 11 years, 7 months ago by
Stephen Houser.
August 14, 2014 at 9:06 pm #235312
I just joined and made some introductory comments. A few people kindly replied and gave me some good suggestions. I tried to respond and thank them but after I responded and clicked “post new topic” I got the following message:
Microsoft OLE DB Provider for SQL Server error ‘80040e2f’
Cannot insert the value NULL into column
‘Forum_ID’, table ‘devinew_forum.dbo.tblEmailNotify’; column does not
allow nulls. INSERT fails./forum2/new_post.asp, line 1404
Apparently my replies have been going nowhere. If there’s a solution to this, please advise.
Thanks,
Dave
August 14, 2014 at 9:20 pm #260976Dave, I’ve been on this forum for 5 years and I get that message every time I post. Doesn’t matter, the post goes up.
August 14, 2014 at 9:25 pm #260977Thanks. I got it when I put up my initial post, and I realized that the post went up, but it appears that’s not the case with a reply. But based on what you’ve told me, I guess it’s just something I’ll have to get used to.
August 14, 2014 at 9:53 pm #260978They should go up. If you just hit the “back” button on your browser it won’t be apparent. But if you refresh the browser your post should be there. If it isn’t then we have a problem above and beyond my technical expertise.
August 14, 2014 at 10:11 pm #260979Indeed, I see it’s actually working. My apologies to those I unintentionally spammed.
August 16, 2014 at 12:03 pm #260980If you uncheck “email notify me of replies” just above the post reply button when replying it does not generate the error any longer. You can also change it in your member settings control panel.
Buxton, Maine
1982 London Roadster - "Kit Kat"August 16, 2014 at 6:52 pm #260981made the change…this is a test
"Drive Happy"August 16, 2014 at 6:53 pm #260982Dang it all…IT WORKS !!!
Thanks
"Drive Happy"August 16, 2014 at 7:31 pm #260983Test
August 16, 2014 at 7:32 pm #260984Wow! Magic.
August 16, 2014 at 11:17 pm #260985Just checked it and you’re correct. It works. AND……………..I found that if you check in the file manager in your member settings control panel, you’ll see all your posted photos.
"If one thing matters, everything matters" - from the book The ShackAugust 17, 2014 at 9:49 am #260986How about them apples? I never even noticed that check box before.
August 17, 2014 at 2:00 pm #260987
TDREPLICA Map
August 18, 2014 at 2:43 pm #260988All the knowledge gained from going back in time and reading nearly every thread has paid off!
Yes… nearly every thread….
I was bored waiting for parts.
Buxton, Maine
1982 London Roadster - "Kit Kat" -
