Led Bulbs
Home Forums General Discussion Led Bulbs
  • #234145
    Mike
    @mike-n-scarlett
    I just got my LED bulbs in. They must have came on the proverbial slow boat from China (Hong Kong) because it took two weeks to ship.
    I bought 45 LED 1157 and 36 LED 1156. Great price $4.00 including shipping For a pack of two. I installed one side at a time so I could compare brightness. The results: save your money here. The bulbs worked fine, but were not as bright as original. The flasher worked fine as I left the original bulbs in the front. Some may have already tried this with same results. These LEDs can be classified as a novelty item.
    Mike N Scarlett2012-05-19 09:02:12
    #250518
    Paul Allain
    @pga64
    I had the same result. I spent a lot more money than you did, and found that the originals were brighter.
    #250519
    Mike
    @mike-n-scarlett
    I had high hopes for these pga64. I even did the research that explained why you use the same color bulb as lens color. This didnt make sense to me at 1st as it would seem that a white light would produce more light through a colored lens. The explanation was that with LED a red lens would filter out most of the color but red.
