Links in old posts
Home Forums Site Site Input and Issues Links in old posts
  • #233998
    Hi folks,
    As part of the recent software upgrade, FrankieD had to build a new database for forum posts. He was able to copy all our old posts into the new directory. But because of the new db, the address has changed and any in old posts to other threads will nolonger work.
    The fix is easy.
    Every link to a thread in the forum begins with http://www.tdreplica.com/forum/ and needs to be revised to http://www.tdreplica.com/forum2/
    As I run across links, I will edit the post.
    If you recall any of your own posts that have links, dig ’em out and edit them. (Click “Post Options” and then click Edit Post).
    If you see a link in someone else’s post, let me know about it. The admin’s can edit anyone’s post.
    #249321
    I’ll try to remember this. Thanks for the heads up.
  • The topic ‘Links in old posts’ is closed to new replies.
