Location of Running Board Supports
Home Forums General Discussion Location of Running Board Supports
  • #232994
    Bill Stuck
    @billsflorida
    I have attached my front fenders and running boards — now I need to position the running board supports on each side.  There are no pre-drilled holes and the support could be located just aft of the Fender/running board joint
    OR
    as much as a foot further aft. I would like to set it at the place that the most weight would be applied as people get into and out of the car.   Since I have never seen a completed car and my seats are not ready for installation  –can someone give me a recommendation.   Thanks!
    #241422
    Bill,
    I can’t help with locating the support. Classic Roadsters running boards attach to the front and rear fenders and to the body, but do not have an additional support.
    But regardless of where you locate that support, I recommend you not let anyone actually step on the running board. I’ve never tried, and have never seen any of my TD friends try.
    Just my humble opinion.
    #241423
    Gene Jenkins
    @jenkinen
    Have you read the manual? I don’t know about the Chevette manual, but the Ford manual says, on page 53: “Center the running board bracket…..”  My brackets (Ford) are about centered on the door.
    The Ford Fiberfab and the Chevette CMC manuals are available on this site for download.
    #241424
    Bill Stuck
    @billsflorida
    Thanks for the input.   I wondered whether this running board was more for style — than function.   I would not have stepped on it — but others may try.
