Home › Forums › Classifieds › MGTD Kit Cars Unfinished › Need a picture of a Chevette Sway Bar
- This topic has 9 replies, 5 voices, and was last updated 11 years, 10 months ago by
PAUL Burkheimer.
August 7, 2013 at 9:21 pm #234837
I have an FiberFab MGTD with 84 Chevette running gear. The cat was built in 85 with 84 Chevette parts that had 6 miles. Part of a salvage from a train derailment. There is no front sway bar on it and I need to see a picture of a Chevette based car with the sway bar mounted. The original assembly manual doesn’t say anything about it. This car has 3,200 miles since 85. 1,300 miles were put on it in Mat 2013 when I drove it from San Antonio, Texas to Grand Rapids, Michigan. The TD had been in my brother’s back yard since July 1993.
If you have a picture showing where the sway bar mounted, this would really help, Thanks, James McGahee, jmcgahe@aol.comAugust 7, 2013 at 9:47 pm #257284August 8, 2013 at 3:32 am #257285Does it even need one? My Ford based kit doesn’t use it.
"Drive Happy"August 8, 2013 at 8:04 am #257286That’s amazing, Bill. All that setup, engineering and the rest–and all for autoX work– & no sway bar? Why not?
August 8, 2013 at 12:45 pm #257287If you were to mount it it would be out at the front of the body beyond the grille. No frame there to mount it to. It also seems to be unnecessary.
"Drive Happy"August 8, 2013 at 9:39 pm #257288Here you go!
August 8, 2013 at 10:36 pm #257289Thanks Ringo, Every bit of information helps. I finall found a good copy of the Chevette maintenance manual. In labor and toil, all things are accomplished. Driving on.
James
August 9, 2013 at 3:33 am #257290The Chevette bar bends in the opposite direction than the Pinto unit…I wonder…
"Drive Happy"April 15, 2014 at 7:30 pm #257291My chevette FF kit does not use the rollbar
April 15, 2014 at 7:32 pm #257292My chevette kit from Daytona is a FiberFab kit and does not use the rollbar
