Home › Forums › General Discussion › Neutral Safety Switch
- This topic has 5 replies, 6 voices, and was last updated 10 years ago by
KentT.
January 14, 2016 at 9:17 am #235994Had a bit of time whilst waiting for a service tech to get to the house and browsed Painless and Rebel wire kits. Each mention a Neutral Safety Switch in their kits. What is the purpose of this switch?
ThanksAllen Caron
"If one thing matters, everything matters" - from the book The ShackJanuary 14, 2016 at 10:57 am #266899Anonymous
InactiveNeutral start switch makes sure you are not in gear when you start your car. If not used car can move when you start without one and you have car in gear.
January 14, 2016 at 12:20 pm #266900Thankfully, I don’t have one. If I did, I wouldn’t have gotten home the night my clutch cable broke. 😉
 (Started car in 1st gear, and drove 2 miles on the shoulder in 1st)Paul Mossberg
January 14, 2016 at 12:30 pm #266901On my way home from purchasing a 911s about 25 years ago, my clutch cable broke. I learned how to shift without a clutch. But timing stoplights (so you don’t have to stop) remains the tricky part.Â
January 14, 2016 at 6:45 pm #266902Hadn’t thought of that being an option on these cars, I’ve managed to try starting in gear only a couple times. Maybe I’ve learned my lesson by now. Been more than 25 years since I had “4 on the floor” until getting my TDr.
My Yamaha motorcycle has this too, wired at the clutch lever and shifter so doubly “safe”. Many people bypass it the moment there’s electrical problems. A motorcycle probably jumps forward more than a car, and a car less likely to fire up I guess.January 14, 2016 at 9:57 pm #266903To my knowledge, no standard 4 speed Bug had a neutral safety switch. The Autostick may have had one as part of the electric clutch servo wiring, but it has been too long since I was around one, that I can’t recall.KentT2016-01-15 11:33:00
