Home › Forums › MGTD Kit Cars › VW Based Kits › New Gas Tank Install Problem
- This topic has 32 replies, 10 voices, and was last updated 12 years, 6 months ago by
June 18, 2013 at 8:07 am #256217
x2 on the vent hose.
June 18, 2013 at 8:49 am #256218This is how I ran my vent line. It is attached to high point of firewall so any liguid will drain back into tank.
Al
June 18, 2013 at 8:50 am #256219My tank will have a marine flip top outlet connected to the neck in the tank, with the two connected by a rubber marine grade filler neck hose. This is done on boats all the time. You may consider this instead of trying to weld a filler neck to make it shorter or longer….. See my build stream for Alfred under My Projects.
June 18, 2013 at 9:31 am #256220Al Greig wrote:This is how I ran my vent line. It is attached to high point of firewall so any liguid will drain back into tank.Al
Good technique, and great illustration, Al. The PO for mine actually installed the factory carbon canister (used to trap fumes) down underneath the gas tank, on the passenger’s side. Over the years, it has become a grimy, somewhat greasy mess. Yours is much simpler and cleaner, yet adequate, solution…Early FF TDr on 69 VW pan
Slowly coming back from the ashes...June 18, 2013 at 10:26 am #256221Re the vent hose….I have the hose, just haven’t installed it yet. The PO has carpeting in the front area and I’m looking at how best to route the vent hose without having to tear out the carpet. I was so glad to get the new tank installed and checked out that I didn’t jump on the vent hose right away. You all know how these projects go, it is never “pull out the old and install the new” I had several other items that came up in the process that I wanted to correct as well. As soon as I get back from our trip, I’ll get it installed. I like the routing suggestions. Thanks.
SamSeptember 19, 2013 at 7:02 pm #256222Ok..I have a question regarding the fuel level sender. When you look at the earlier pic of my new tank install the fuel level sender is installed such that the float arm is on the left side (the side where the filler neck is). I put about 4.5 gal of fuel in the tank and the gage showed a little less that 1/2 fill so I thought it was ok. I’ve driven the car some and the gage now reads empty, but when I light a match to look into the gas tank (just kidding)..when I look in the filler neck using a flash light, there is gas in the lower center section of the tank and the float appears to be on top of the gas. So I’m wondering now if I have the sender mounted in the correct position. Can somebody confirm? If not, what is the correct mounting position? If it is the correct position, then what might be wrong? Thanks.
Sam
September 19, 2013 at 8:25 pm #256223Sam,
Not exactly certain but it may be a tab issue. The float arm meets a tab and I THINK you bend the tab up or down to show empty/full. I’ll check my Ghia note. It had the same type of issue.Allen Caron
"If one thing matters, everything matters" - from the book The ShackSeptember 19, 2013 at 11:00 pm #256224The fuel sender only fits one way, those five screw fittings are not equally spaced.
I don’t have a VW tank in my Duchess…but your set up sounds correct. I suspect the “bowl” at the bottom of the tank provides a reserve beyond the gauge reading empty.
