Home › Forums › General Discussion › oil cooler
- This topic has 5 replies, 3 voices, and was last updated 12 years, 9 months ago by
greg press.
May 17, 2013 at 5:17 pm #234687
my mechanic thinks i need a new oil cooler because it is dripping oil where do i find one
May 17, 2013 at 7:11 pm #256011Here are a couple of places.
"If one thing matters, everything matters" - from the book The ShackMay 17, 2013 at 9:03 pm #256012Does anyone have an idea of which one will fit my london he has not taken the old out. Maybe it needs only the seals an if it only needs them which ones.Do the coolers go bad seems to be used ones on ebay
May 17, 2013 at 10:17 pm #256013Anonymous
InactiveGreg: Is your engine a single port or dual port? If unsure check serial number of engine. Check serial number with the list on SAMBA VW. They will have year of engine. 71 and later engines have a dog house oil cooler installed. It is slightly different than the earlier ones. Larger oil passages.
Some engines use a remote oil filter They can be mounted almost anywere.As for your oil leak I would clean the area real good and take it for a run and check. A lot of vw oil coolers are loose and that can cause a big oil leak.Oil cooler can be removed with engine installed but is a pain. Easier to pull engine and get a good look at it. Oil seals and oil cooler if needed can be bought at vw parts houses.Hope it is just a loose nut or bad o rings.May 17, 2013 at 11:09 pm #256014Greg: Some folks when they install their oil coolers, be they standard or doghouse oil coolers, they over-tighten the nuts that mount the cooler. When this happens the seals deform too much and start leaking. The problem gets compounded if the engine has a doghouse cooler because there are two sets of seals; the set between the oil cooler and adapter and the set between the adapter and the engine. The engine seal kits USUALLY have the seals for both types of oil coolers and can be purchased at any NAPA, Pepboys, Autozone etc. The last seal kit I purchased cost me 19.95 at NAPA.
Hope this helps.newkitman2013-05-17 23:10:30
"If one thing matters, everything matters" - from the book The ShackMay 23, 2013 at 7:34 pm #256015Just to give you an up date . After ordering new seals they are the wrong ones .As it turns out someone did a repair on the one that was taken out It beats me why some one would repair one when you can buy a new one for 80 bucks It takes alot to take one out.Should be up and running next week cant wait
