Home › Forums › General Discussion › oil pressure gage
- This topic has 7 replies, 5 voices, and was last updated 10 years, 12 months ago by
greg press.
March 31, 2015 at 3:59 pm #235663
Late last summer my oil pressure gage quit working . I’m sure oil pressure is good because I drove the car many miles when gage said 0 and it run good .When you turn ignition switch on it jumps and goes back to 0 .I checked the fuses they look good . There is a 2 inch plastic enclosed inline fuse that I have yet to take apart . But I plan to soon . I put a new sending unit in [nothing changed] I checked the wire going to sending unit no power [ I checked it with one of those lights with the alligator ground clamp.] When the car is running should there be power there . When the car is not running with the key on should there power there.
March 31, 2015 at 5:58 pm #263942Greg. You don’t have Teflon tape on the sender threads that thread into the engine block do you? The Teflon tape interferes with the ground. Just a thought ❓ If not, from what you say you have either a missing wire or a bad gauge.
"If one thing matters, everything matters" - from the book The ShackMarch 31, 2015 at 7:06 pm #263943The in-line fuse should be the very first thing to check.
March 31, 2015 at 7:17 pm #263944amen
"Drive Happy"April 1, 2015 at 3:57 pm #263945In line fuse looked good . I replaced it anyway. If I remove wire from sending unit and test it with my test light should there always be power there when car is running
April 1, 2015 at 4:24 pm #263946Make sure the gauge is grounded properly. Make a new temporary ground wire and run it straight from a known good ground to the gauge. You could also make up a long wire to run from the sending unit to the back of the guage. Check for power at the back of the gauge.
April 1, 2015 at 4:31 pm #263947Dean’s got the right approach.
April 1, 2015 at 4:57 pm #263948That’s exactly what I was thinking . I thought I would check with you guys before I started something that wasn’t necessary .
