Trying to install the clutch, brake and gas pedals on my CMC Ford kit and have very little room between the brake and gas pedals. Does the brake pedal need to be heated and bent to the left to create room or is there another solution.
It also looks like the distance from the clutch pedal to the clutch cable is several inches more than the length of the clutch clip. Do i need to create some kind of extension for this?
Looking for a picture of where the wiring harness is routed through the firewall. The wiring diagram I have isn’t clear. Looks like the main harness and both the front and rear harness connectors need to go through somewhere;
So many questions- Thanks much. When I get these solved I will be on the downside of this build!!
Flip
PMOSSBERG2014-05-19 21:51:32
