Home › Forums › MGTD Kit Cars › Chevy/Ford Kits › Pinto engine size
- This topic has 7 replies, 4 voices, and was last updated 17 years, 4 months ago by
Steve Crites.
November 15, 2008 at 10:22 pm #232477
I have a ’52 MG TD roadster rep with a Ford Pinto engine in it. What are the clues to engine size on the engine?
Many Thanks
Jennifer Williams
November 15, 2008 at 10:36 pm #237807Hi Jennifer,
Here is the web site for the Ford Pinto Car Club of America.
http://www.fordpinto.com/smf/index.php
If you don’t find the info from the TD fans on this site, I bet the Pinto fans can help!
November 16, 2008 at 4:34 pm #237808Hi Jennifer,
I also have a pinto engine in my MG. Mine is a 2.3 liter, I bet yours is too!
If you know what year of pinto the engine came from you could try a chiltons manual from the auto part store too.
Good Luck
November 16, 2008 at 6:57 pm #237809Jennifer:
Most likely it’s a 2.3 Liter. The web sites for the Pinto and Mustang II gang will give you some guidance to make sure.
Once you’re sure, check Amazon for a manual. (I prefer Haynes manuals, much more detailed, IMO)
Also check out sites listed under the search for 2.3 Liter Ford such as Racer Walsh and Esslinger, for aftermarket performance mods if you’re interested in such things. These engines are used even now for sprint and some drag boat racers, so parts are available from basic to upgrades.
Ringo
November 18, 2008 at 12:36 am #237810Not getting much joy from the Pinto site, signed up but they still haven’t approved me yet! (Wonder what I did to offend them?!?)
Will try the others you suggested, Ringo. Not that interested in performance unless it involves reducing gas consumption, up here in Canada it’s EXPENSIVE compared to you over the Line.
Will follow up
TTFN Jennifer
November 18, 2008 at 9:21 am #237811Jennifer:
Checked my manuals and the quickest way to tell size on the Pinto (Lima) engine is by the oil filler cap. On the 2.0 L it’s at the front of the engine, on the 2.3 L it’s at the back of the valve cover. (closest to the driver). There’s other ways but this is the most obvious.
Sorry I didn’t check these sooner. Hope it helps.
Ringo
November 18, 2008 at 12:11 pm #237812Well I’m blowed, looks like I’ve got a 2.3!!!!
Thanks X 1,000,00 Ringo!!
TTFN Jennifer
November 18, 2008 at 12:32 pm #237813Jennifer:
Good news, since those engines appeared in vehicles up to the 90s. They appeared in everything from Mustangs to Rangers to Aerostars. Most replacement parts are easily available at any auto part chain stores. They run well and are almost bullet proof. Almost any shop worth it’s salt has working knowledge of them so it’s not such a chore to find a mechanic.
Ringo
