Home › Forums › Site › How-To Do Things in the Forums & on the Web-site › Posting Pictures
- This topic has 5 replies, 4 voices, and was last updated 8 years, 10 months ago by
newkitman.
December 31, 2016 at 3:33 pm #302699
While we work on a better solution and with a thousand thank yous to Ed for documenting the current process…
There is a way to post pictures but it is a bit complicated & clunky. Here’s the process, as of now:
- go to the upper right part of the screen where it says “Howdy, ricrx7” and hover your cursor there. You’ll get a dropdown menu.
- On the bottom of that menu, hover over “media.” That will give you another dropdown.
- Click on “photos.” That will bring you to another page, where all your pictures are. You probably have none.
- Right under where it says “All Photos” you’ll see “upload.” Click on that.
- You’ll see a little box where you can drag and drop a photo. Do that. We’re making progress, but we’re not even close to done…
- Once your picture loads, it will join the little gallery (or start the little gallery) on the page you’re at. Click on it.
- Now your picture should be full size. You need to click on it again, with the right-side mouse button. You should see another box open in the middle of the picture. In the middle of your choices is “Copy Image Address.” Click that.
- Now hit your browser’s “back” button (or left arrow) to get back to the part of the forum you want your picture in. Like right here.
- Above your dialogue box is a gray bar with a smily face on the far left. The second icon from the right end is a jagged mountain with a setting moon. Yeah, that’s it. Hover over it and it says “Insert/edit image.” Click that.
- You’ll open yet another box. This one has a box in it marked “Source.” Put your cursor there and hit control V. That will paste the address of your photo in it. Then hit OK.
- And your picture should appear in the post!
January 2, 2017 at 9:10 pm #302727With thanks to ric, here is a shorter version of the posting instructions.
1 Howdy – hover – select Media – select Photos
2 All Photos – Upload – Select your File
3 Click for full size – right click for options – select Properties – copy address
4 Go to desired location to post picture
5 Make sure Visual box is selected and click icon for images (picture of mountains)
6 Cursor on Source – right click – paste (or Ctrl V)
Pictures need to be in your Gallery before they can be placed in a post. Then posting a picture is basically the normal computer steps of “copy address” and “paste address.” Although the picture address needs to be copied before any text is written in a post.
January 8, 2017 at 8:35 am #302757That was very helpful thankyou for your information
April 19, 2017 at 3:47 pm #303494Only problem I’m having is I cannot post more than one picture as I have to have the location copied to the clipboard before I write because if I navigate away from the page to get another pix everything I have written is deleted and I have to start with a clean page.
Fix?
April 19, 2017 at 4:10 pm #303495OK I’ve been cruising around the site and everybody is posting multiple photos soooo,….give me the dunce hat.
Somebody tell me what to do. 🙂
April 29, 2017 at 10:50 am #303530Okay. I had some damage to my passenger door due to the severe storms. I removed the door, made the repairs and am currently painting. I have some photos to post which leads to these questions.
(1) When I first add a photo, I go to my gallery and add the photos; then in the topic post, I select the photos I want to add and cut and paste. Correct? (2) Currently I have no photos in my gallery. Create my gallery (yes/no) or does it automatically create it when I select it?
Thanks for the help.
