Home › Forums › General Discussion › power inverter
- This topic has 6 replies, 5 voices, and was last updated 13 years, 10 months ago by
greg press.
April 13, 2012 at 11:33 pm #234097
Today i did something a little strange.My speedometor has never been right but i decided it wasn’t worth fixing and my radio hasn’t worked well.I had a 400 watt inverter so i hooked it up to the battery hid the inverter under the seat attached a old gps that i had laying around and a old boom box.I also hide all wires. GPS is on the hump in front of emergency brake.[hope the satilite will it]. I not only used up my junk ,i now have the correct speed i’m going,satilite directions so i can find my way home and i can listen to great music above the roar of my engine. Tomorrow i will give it a try.
April 14, 2012 at 10:24 am #250055Things that make you go hmm……………. Nice idea. Hope it all works well for you.
"If one thing matters, everything matters" - from the book The ShackApril 14, 2012 at 12:10 pm #250056It works.The only problem i can forsee is i wonder how much power it draws. Hopefully not to much. I have to remember to turn it off.
April 14, 2012 at 1:37 pm #250057Since you now have 110vac in your TDr, you could just plug in your battery charger and not worry about it.
April 14, 2012 at 5:15 pm #250058I think if you plug a boom box into a power inverter you’re double-inverting it. The box wants something like eight 1.5 volt D batteries. But they were monster battery-eaters and so they were made with a plug-in cord which converted the house current to 12 volts DC.
So what you’re doing now is taking the 12 volts DC that the boom box wants, converting that to 110/120 ac, plugging the box in, and the box is converting it back to 12 volts.
That’s my guess, anyway.
The inverter makes the TD into a very small camper though. You could plug in a little ‘frige or a hot plate. So I think it’s totally worth having and will totally bring something to plug into it at Carlisle.
How’d it work, BTW?
edsnova2012-04-14 17:16:30
April 14, 2012 at 7:28 pm #250059I have inverters in both my trucks and my camper. Need to charge up some of our toys while were on the road.Also get a battery that will cut off the power if it gets to low or an inverter that has a low battery alarm ?live and learn the hard way, dead battery on camper and truck while camping!!!!!
TDREPLICA Map
April 14, 2012 at 8:26 pm #250060I also came up with another idea.My wife like most women is always cold. She will only go for rides on 75 plus degree days an never at night.I have a small electric ceramatic heater that i heat my 200 sq. ft. work shop with when its 20 degrees out. I could heat the car interior to 100 degrees plus with the side curtians on
