Home › Forums › MGTD Kit Cars › Chevy/Ford Kits › Rear Spring Problem
- This topic has 3 replies, 2 voices, and was last updated 21 years, 3 months ago by
Mark Hendrickson.
October 19, 2004 at 12:49 pm #232091
I have the Pinto kit. The road clearance seems to be about 4″ when no one is in the car. It drops to an inch or so when we sit in the car. Has anyone been able to stiffen the springs to solve the problem?
ALSO I would like to let everyone know that it was PinkMG that helped me find my car about two years ago. THANKS
Mike
October 20, 2004 at 11:01 am #236176Hi Mike,
As you know, I had the Pinto based kit that I was going to build with the Buick V6/TH200R4/8″ Ford rear drive train. I ended up assembling the rolling chassis, shrink wrapping the body and the parts on it, and selling it to a Sacramento, CA buyer.
You may also remember I was missing the rear spring plate mounts and had to fabricate my own. I also bought new quarter-elliptical leafs from Eaton-Detroit Spring (http://www.eatonsprings.com). I bought the Pinto application semi-ellipticals and had them cut them off to quarter-elliptical. Why pay for shipping the extra weight. Also, they can cut them a lot easier than I could. You’ll need to know the front spring eye to springs center bolt measurement for them.
I also did not use the lame CMC upper link that keeps the rear from rolling. I fabricated two adjustable upper links (control arms) that were mounted directly over the springs. I used swedged tubing, heim joints and some chassis tabs to weld on the rear. (http://www.speedwaymotors.com). This allowed me to adjust the pinion angle perfectly.
If you want, I’ll send the pics I took during the build. I actually had to remove 2 of the 4 leafs from the new springs too. Otherwise it sat too high and was too stiff.
I think you have a dead 30 year old spring problem. Another “fix” could be air shocks or coil helper style shocks. Also, the spring plate mounts could be modified to make the “shackle” part longer, thereby raising the body. You could even put multiple holes in the longer “shackles” for adjusable ride height. Your frame rails should remain very close to parallel to the ground when you and your passenger in the car.
If I was keeping the car I sold and continued the build with the Buick drive train, I was going to fabricate a coil-over or air bag 4 link set up with a panhard bar.
October 20, 2004 at 11:52 am #236177Thanks for the links and information. You are way ahead of me when it comes to designing a system that works. I would like to get any photos of what you did. I plan to rework several items this winter when it gets cold (in Texas?). Anyway after two years I am ready to enjoy it for a little while. If you run across a never touched Pinto kit I would love to know about it.
Mike
October 20, 2004 at 1:31 pm #236178Mike,
The more I thought about it, send me pictures of the way you have the springs mounted. Is it possible that they are installed upside down? The spring eye should be pointed down. These quarter elliptical springs should arc toward the ground, the opposite of how they were mounted in the Pinto when they were semi-elliptical.
I’ll send the pics to you after work.
- The topic ‘Rear Spring Problem’ is closed to new replies.
