Home › Forums › General Discussion › Rim/tire Question
- This topic has 6 replies, 3 voices, and was last updated 9 years ago by
February 22, 2017 at 6:06 pm #303081
My new rims are 15 x 4, 4-lug 4 x 130 rims. Will that impact what tire I can put on them? I want to install 185R15s all around.
"If one thing matters, everything matters" - from the book The ShackFebruary 23, 2017 at 7:02 am #303082I have run 205/60R15 front and 235/60R15 rear with no trouble. No idea what the backspacing is.
"Drive Happy"February 23, 2017 at 6:25 pm #303083Thanks Bill. I guess what I was wondering is will say…a 165R15 tire fit on a 15 x 5.5 and a 15 x 4? As far as I can series it will. Just want to be certain before I go purchasing 5 new tires.
"If one thing matters, everything matters" - from the book The ShackFebruary 23, 2017 at 7:42 pm #303084A 165/70R15 should fit a minimum of 4-1/2″, maximum of 5-1/2″.
A 185/70R15 should be between 5″ and 6-1/2″.
Although I once ran a 265/60-14 on a 4″ wheel. Should have been a minimum of 7-1/2″. It sat flat with 10 pounds of air.
"Drive Happy"February 23, 2017 at 7:53 pm #303085Hmm…now I’m wondering what size tires will fit. More research is in order. Thanks for your help Bill.
"If one thing matters, everything matters" - from the book The ShackFebruary 23, 2017 at 8:45 pm #303086165/80s will go on a 4 inch rim with no trouble. They will look right on the TD and handle fine. I am not sure your regular Mangels are actually 4 inches though. They might be 4.5 inches. I have thought all the stock 8-slot VW rims were either 4.5 or 5.5. Mine are 4.5. (The new wires are 4.5-inch as well)
185s I’d want the 5.5 inch rim.
February 23, 2017 at 8:52 pm #303087And I was wrong. Lots of early Bug rims were 4 inches. This thread has an apparent expert on Beetle/Ghia rim widths and offsets.
I still say 165 R 15s (about a .8 aspect ratio) are the right thing for us & will go on the skinny rims nicely.
