Running fuel line
Home Forums MGTD Kit Cars VW Based Kits Running fuel line
  • #235205
    Ricky
    @mymgtd
    I am getting ready to run a new fuel line in my MGTD. I am planning on running it through a PVC pipe in the tunel to protect it better. Does anyone know any reason why that would not be a good idea? Thanks
    #260455
    This is a steel fuel line or a rubber one?
    Either way, putting it in PVC like it’s an AC wire buried in the back yard sounds like overkill, possibly complicating the job needlessly. I would consider a PVC or other conduit if the line were running under the car, outside the tunnel, however.
    As for me, i copied the Subaru I’m using as a parts car: Ran them along the tunnel on the outside in little plastic clips.
    I got a lot of those clips, BTW, if you want any.
    #260456
    Melvin Collins
    @fairwindsnc
    I would be concerned about moisture and rust out.
    #260457
    Ricky
    @mymgtd
    Ok thanks for the input. I always like to get some input from those of you who have already been through restoring a td.
