Home › Forums › General Discussion › Seatback Foam
- This topic has 12 replies, 7 voices, and was last updated 11 years, 11 months ago by
newkitman.
April 28, 2014 at 4:09 pm #235174
Set the seatback foam on the wood seatback and something didn’t look right. Shouldn’t the foam be about 1/2 inch larger all around like the seat bottoms?
Thanks guys and gals.
newkitman 2014-04-28 16:09:53 Allen Caron
"If one thing matters, everything matters" - from the book The ShackApril 29, 2014 at 6:23 pm #260277Someone’s gotta know this…
April 29, 2014 at 9:15 pm #260278I have a picture but have lost ability to post? looks like a W from the bottom
Can’t get it in private msg either. Will email if you send your address
juneybug2014-04-29 21:43:19April 29, 2014 at 10:02 pm #260279Go to the “Post Reply” on the left side and click on it. You will find the post picture option there.
April 30, 2014 at 5:44 am #260280When I try to insert image I get error msg
April 30, 2014 at 7:28 am #260281Mike, I have the same problem. Only way I could get it to work is to go to my pictures file-copy with rt click and them paste it in the reply area.
April 30, 2014 at 8:26 am #260282
well done Montie Thank you, you’ll probably have to remind me next time
juneybug2014-04-30 21:31:37
April 30, 2014 at 11:16 am #260283finished shows bevel at bottom
April 30, 2014 at 11:33 am #260284Thanks Mike! These pics help a lot.
"If one thing matters, everything matters" - from the book The ShackApril 30, 2014 at 6:08 pm #260285One last question for y’all. In all the pictures I’ve seen of the seat back there is a middle and two edge pieces. My instructions don’t show those pieces. Only shows a single rectangular piece. Do all TDR seatbacks have the center and edge pieces? Just wondering if the fabric from the kit will fit.
"If one thing matters, everything matters" - from the book The ShackApril 30, 2014 at 7:21 pm #260286The seat back upholstery should be a one piece “pocket” that you stretch around the foam cushion.
"Drive Happy"April 30, 2014 at 10:22 pm #260287Allen, the seatback foam and seat cushion foam in my early FF is flat, one-piece stuff..
Slowly coming back from the ashes...May 1, 2014 at 7:23 am #260288Okay everyone. Thanks for all the help. Onward I go.
