!st gear
Home Forums MGTD Kit Cars VW Based Kits !st gear
  • #232116
    Jon Townsend
    @jon-townsend
    In a 1969 VW, 1st gear is geared so low that you must shift almost immediately after starting rolling. Trying to take off in 2nd gear takes too much clutch but it can be done. What have you’all done for this or is it just one of those things you live with?
    #236431
    Mark Hendrickson
    @pink-mg
    The reason for the low 1st gear was that a stock VW is about 900 lbs. heavier than a VW based MGTD kit.
    I used a Stuff Transaxles “Freeway Flyer” transaxle in my car. It did nothing for the lower gears, but made 4th gear higher so that I wasn’t turning high RPM’s on the highway.
    Try calling Stuff Transaxles in Oceanside, CA. He is a VW transaxle Guru named Hank Harris. http://www.bugtrans.com
  • The topic ‘!st gear’ is closed to new replies.
