Home › Forums › MGTD Kit Cars › VW Based Kits › steering column/ fiberglass body
- This topic has 15 replies, 6 voices, and was last updated 12 years, 4 months ago by
Mark.
September 16, 2013 at 3:10 pm #234908
So since I got my MG pre-assembled, it has a few problems in the build. Someone didn’t take their time and do a good job all the time. But on the front of the car between the front left fender and body the steering column exits the body and goes to the steering stuff (brain fart…) but it is not cleanly done and the front fiberglass panel (that goes across the whole front under the grill) is bent out of shape around the steering column etc. Is there a way to fix this or do I just need to get a new piece. (several actually since they cut the grill frame to make room)
Thanks, and I will post a picture or two once I’m home from work this evening.September 16, 2013 at 3:45 pm #257715Sounds likwe you have an early FiberFab MIGI.
In reaserching the diferences between the various manufacturers (see this thread) we learned the earlier cars had a one piece fiberglass grill shell that incorporated the front splash panel as part of the piece. The metal grill was optional and could be fit over the fiberglass.Cars that had this grill had two major differences:
1) The steering column exited the left side panel and was clearly visible then tucked under the left side of the splash panel.
2) The front left fender was different.
Your comment about the bent bodypanel makes me believe the access hole isnot cut correctly. Before you hunt down and buy a replacement body side panel, are you able to just clean up the hole so the column fits through neatly?Paul Mossberg
September 16, 2013 at 10:53 pm #257716So I read through that forum a bit and I believe I have a Daytona Migi with the separate panel in front of the fenders that bolts on.
I don’t know if you can see very well in this picture but it is lifted on the left side of the car.
And as you said the hole cut in the body panel is sloppy but that will be no problem to clean up.PMOSSBERG2013-09-17 10:50:19
September 16, 2013 at 10:55 pm #257717Did that image work? It doesn’t appear on my iPad.
September 17, 2013 at 10:48 am #257718Hey nobody.
I fixed your post.The img and /img codes work here. But you need the full web address.Your initial post had only a portion of the address (“uploads/27973/image.jpg”)PMOSSBERG2013-09-17 10:53:21
September 17, 2013 at 12:27 pm #257719I also have an early FF kit, as best I can tell, with the exposed steering shaft. Mine also was already built with some build issues – but my errors are on the rear and not the front.
On mine, there’s rubber pads about 3/8″ thick that go between the fiberglass front grille piece and the mounting bolts on the top torsion tube. This raises that front grille piece enough that it clears the steering box, without having to trim it (as shown in your pic) to clear the gear lash adjustment screw. My grille piece sits on top of the steering box. Not sure how that slight difference in mounting height might effect the issues that you’re dealing with.Early FF TDr on 69 VW pan
Slowly coming back from the ashes...September 17, 2013 at 12:47 pm #257720Can’t help much here guys. My ff kit is the later model with my front fenders having the center piece molded in with the fender and meeting in the middle in front of the grille. Right now the pieces that fit in front of the grille, the driver’s fender just sits on top of my steering box with the grille resting on the torsion bar just in front of the lower tube of the front beam. Does anyone know how far in front of the front beam the fender piece should be? My assembly manual doesn’t give a measurement, just says to bolt the front bumper bracket to the mount bar on the front beam.newkitman2013-09-17 12:50:13
"If one thing matters, everything matters" - from the book The ShackSeptember 17, 2013 at 7:43 pm #257721Thanks Paul.
The rubber is a good idea, but then it seems like there would be a gap between the fender and the bottom of the grille/front splash piece.I was originally thinking of cutting out around the steering column and box then making a mould of the box in fiberglass, this way the fiberglass grille piece sits flat on top of the fender.Thoughts on this?October 5, 2013 at 3:22 pm #257722Hey Paul Mossberg. You said the left front fender is different. Is that why my tire rubs on it? What do I do about it?
Two BladesOctober 5, 2013 at 6:32 pm #257723MArk,
“Happy Jack” wrote that comment about the left fender. I was just quoting him.
Here is the thread where he made the comment:
https://tdreplica.com/forums/topic/fiberfab-migi-vs-migi-ii/Paul Mossberg
October 5, 2013 at 7:00 pm #257724Guys and Gals,
Is it possible that the left fender fits differently because it has to? Right up front on the left side of the front beam near the fender is the steering box. There is no object like that on the right side and I’ll bet that’s why the left front fits differently than the right front fender. But then again…although I’ve worked VWs since 1979 I’ve only worked TDrs since two years ago. And I’m still learning all the time.newkitman2013-10-05 19:02:07Allen Caron
"If one thing matters, everything matters" - from the book The ShackOctober 5, 2013 at 9:19 pm #257725Sorry…I thought it was you.
October 5, 2013 at 10:11 pm #257726Allen might be onto something. Look at the fenders from the front and see if they hang “even.” You may be able to pull the left one up just a bit by adjusting the headlight bracket….somehow.
Or your car could be like mine, which is just a tad off center. My left front tire is almost flush with the fender lip, the right side is tucked under a half inch.If you were to narrow your beam 2 inches it might solve the problem. Word I get is you can do it without threading the tie rod & etc. further, as there are enough threads to absorb the narrowing. I’m still kicking myself for not going with the new narrowed adjustable beam when I bought mine three years ago.October 6, 2013 at 11:54 am #257727I cast my vote for some sort of fender misalignment.
Remember…these car parts are hand made…and then hand assembled…perhaps by knuckleheads like us who may (or may NOT) have been expert mechanics.
I know I wasn’t. And no one will ever know by looking at my car curbside, but I do know where the assembly errors are.
October 6, 2013 at 12:16 pm #257728I’m going out now to check measurements. then look at moving my light bracket ( the hood side) in a bit to pull the fender up. Thanks for the help.
October 9, 2013 at 2:04 pm #257729I’ve worked with the bracket but no help. I have a fix for now and posted it on the fender rubbing thread. Thanks for all the input.
