Steering shaft question
Home › Forums › General Discussion › Steering shaft question
  • #232792
    Leon
    @winnipaw
    Does anyone have an opinion about the best year VW steering shaft to use on the Fiberfab MGTD. I believe I have a 1971[shaft] and It just doesn’t fit the way it should. The shaft mounted key cylinder is too low, even with making adjustments. I read, somewhere, that the earlier shafts are a little better fit. Maybe 1968 or earlier. I’m new to this forum and would like to be active. So far I’m having a good time with the car. Cant wait to start cruising it. Gotta get it fixed up a bit for safety sake. Good to be here.
    #240005
    Mark Hendrickson
    @pink-mg
    check out: http://www.thesamba.com/VW
    Join their forum and start asking questions. I am not sure what year VW started the shaft mounted ignition switch.
    My VW based car had a plain column with the blinkers and ignition switch mounted on the dash.
    There are companies like Flaming River and IDIDIT that would probably have a column that would work great too.
    #240006
    Leon
    @winnipaw
    Thanks for the tip. I’ll check them out.I’ll also post my results
