Tachometer connection
Home Forums General Discussion Tachometer connection
  • This topic has 3 replies, 4 voices, and was last updated 4 years ago by Vern.
  • #307666
    Kenneth Irvine, Jr
    @ken1946
    Took out my non working tach and finally found a so so replacement. Of course I have misplaced the original. Can anyone tell me which wires get connected where so I can install the new tach.
    Thanks for any help.
    Ken Irvine, Jr.
    #307667
    crash55
    @crash55
    there are only 4 connections usually negative (ground) positive (power)  signal (comes from ignition coil where the dist . wire connects ) & power for light you can probably look up the info from the tach . brand’s website keep us informed on your progress
    #307668
    Ground (GND) to ground. Positive (red, +) to key switched +. Lights are a + wire from the dash lights or the headlight switch. Finally the green or signal wire goes to the negative (-) terminal on you coil. done.
    vid: https://youtu.be/BLPhQrOnCCc
    #307988
    Vern
    @vmaxey
    I have a MP Tachometer. In good shape but don’t know if it works. Does anyone need or want this
