I am adding a tachometer to my VW based car. The instructions state to connect the ‘red wire’ to positive, ‘black wire’ to negative, ‘white wire’ to lights and the ‘green wire’ to the ‘negative side’ of the coil.
There is a big, fat BLACK wire that goes from the coil to the TOP of the distributor cap and a small GREEN wire that goes from the coil to the SIDE of the distributor.
My question is, is the ‘negative side’ of the coil the GREEN wire that goes between the coil and the distributor? None of my VW books calls that wire the ‘negative side’ but the wiring schematic shows that wire going from the coil to the distributor then on to ground.
THANX for the brain pick! 😀
