Home › Forums › General Discussion › tail lights/ mirrors
- This topic has 9 replies, 5 voices, and was last updated 13 years, 7 months ago by
Larry Murphy.
September 3, 2012 at 10:29 pm #234293
Lucas type mirrors and tail lights on ebay at NOS Locators Fast shipping and priced affordable get them at ebay@noslocators.com or phone at 401 725 5000
September 3, 2012 at 11:34 pm #251737If you are trying to search for this seller on Ebay, search for the seller NOSLocators (no spaces)
September 4, 2012 at 12:20 am #251738Dan is this what your after?
Dan I’ve bought from them before very reliable very quick response.
ray102012-09-04 00:26:29
TDREPLICA Map
September 4, 2012 at 7:50 pm #251739How’s the quality?
September 4, 2012 at 9:39 pm #251740Good quality and fast delivery,and they had what i wanted
I broke a tail light and they had them in stock. /Lucas L549/with shipping 21.97 a pair . they also have Lucas style mirrors.September 4, 2012 at 10:08 pm #251741Dan, Are you referring to the tail light assembly or only the lens? If I’m looking at the same item ,the light assemblys are $31.99 each. Still a good price. I’m thinking about replacing the VW lights on my London Roadster and these are the most reasonable ones that I’ve seen.
September 5, 2012 at 2:09 pm #251742Larry ,,that is for the lens [pair] the L549 is a good fit for the ‘ lucky”lens and assembly that came on my TD, these lenses were used on many cars built in the United Kingdom in the 50s through the early 60s… I broke one with my buffer
I do not know if it would fit on a vw base. on ebay TD parts I have seen assemblies for MG TD, Morris Minor ,Triumph ..ect. Jaguar. used the same base. but a glass lens and are 10 times the price for the same thing…. Good Hunting,,, DanSeptember 5, 2012 at 6:17 pm #251743Thanks Dan, I think I would need to use the complete assembly to make it work. Still not a bad price though.
September 5, 2012 at 10:17 pm #251744Larry what size are the lights you have on your TD now? i do not know the size of VW tights but there many custom light kits for VW . also there many hot rod lights with assembly kits that may look good, like you can find at mikes-afordable.com ……..good luck Dan
September 6, 2012 at 9:37 am #251745Dan, I have the typical VW lights, as used on most TD replicas. However, it is set up with two double filament bulb sockets which mount directly to the fender.The VW lens and trim ring simply mount directly over the bulbs and sockets. The top bulb is for tail light & turn signal , the bottom bulb is for tail light & brake light. Works great and are very visable , I was just thinking about changing top something that would not be instantly identified as VW. What ever I change to would need to use two separate bulbs or I would have to rework the wireing.
