Home › Forums › General Discussion › The New Kid in Illinois
- This topic has 9 replies, 6 voices, and was last updated 9 years, 7 months ago by
Russell Rowe.
September 11, 2015 at 12:35 pm #235842
I recently purchased a very fun “London Roadster” based on a VW engine and transmission.
What is the original manufacturer of the London Roadster?
I am looking for minor parts, i.e. wiper arms, headlamp bulbs, etc.
Are these generic type parts or factory specific?
Any help is greatly appreciated.
Thank You!Amor Conquista Todo
September 11, 2015 at 1:38 pm #265435Hi Steve,
Our LR were built by London Motor Corp in Inkster Mich -Most were factory built which gives our London Roadster less suspect to shoddy or short cuts in the build as might be in the Kit Car models ..or short cuts made by the kit car builders 30 years ago …I own a ’86 LR with custom tubular frame and a 1776cc engine, rack and pinion steering – btw I de-blinged the 80’s look here..There were two models produced per sey:LR TD’s with a VW chassis and running gear and a custom tubular chassis with VW running gear.Our engines have been modified to 1776 cc from the standard VW bug engine i guess that’s why my engine has no serial number.Do you have the manual?I would be happy to email you a copy of one or snail mail either way PM me if you wish .Most of the parts can be had a Moss motors,MG Magic,etc and your local VW air cooled type 1 mechanics and those that are on line . I am sure the guys here will add to this ..Royal, and Edsnova plus Paul are great resources……Welcome aboardpost pics…
jebarry2015-09-11 21:11:19
September 11, 2015 at 6:37 pm #265436greg here from buffalo NY area I to own a LR . lots of fun Waite until you take it to shows. Be prepared for lots of questions .
September 11, 2015 at 8:49 pm #265437Wiper arms should be VW from the donor car. There are differences year-to-year in the ’60s VWs as to how the arms attached to the motor studs. Remove your old ones and get the same style. You may also have to cut the blades a little. Headlights are generic. A lot of people go with modern higher-intensity bulb conversions, but it pays to make sure you’ve got headlight relays and good wiring before installing those.
Wiring on most of these cars is suspect: either it wasn’t done all that well, or it was…but 30 years ago. I try not to drive too much at night. Or in the rain.:lol:April 18, 2016 at 2:21 pm #265438Need wiper blades or arms with blades if necessary. Where can they be purchased? Have a 53 MGTD on VW chassis. Takes 9 Inch blades.
April 18, 2016 at 3:55 pm #265439Here is the link for where to find both.
This will fit just about everything.
Hope it helps!http://www.mgmagicclassicmotorparts.com/windshield-wiper-arm-blade-complete-set-of-two
Take Care!Amor Conquista Todo
April 19, 2016 at 11:10 am #265440Loosened nut on shaft. Is the gear pressed on?
April 19, 2016 at 12:24 pm #265441Can I attach a picture of my wiper assy to a post?
April 19, 2016 at 1:46 pm #265442You can also find 9″ wiper blades on e-bay. You can also just google 9″ wiper blades. They are around.
April 19, 2016 at 10:59 pm #265443Thank you for suggesting “google”. Am trying a pair.
