Home › Forums › MGTD Kit Cars › VW Based Kits › Tire pressure
- This topic has 4 replies, 5 voices, and was last updated 10 years, 1 month ago by
February 2, 2016 at 11:39 pm #236014
I have a VW based FF TD with fifteen inch tires. I have the tires inflated to 32 pounds all the way around. The car rides hard like the tires are very hard. I am not sure of the weight of the car, but since it is fiberglass and should be lighter than it was as a VW sedan, I was wondering if I could reduce the pressure to obtain a smoother ride. I know low or very low pressure can ruin the tires and adversely affect the handling of the car. I have only had this car for a few months, so I am asking those of you that have had the TD’s for a good while, what would be the recommended tire pressure…good for the tires and at the same time, good for a smoother ride. Thanks !!!
February 3, 2016 at 12:01 am #267202Use 15-18 PSI in the front, and 24-26 in the rear. May take a bit of experimenting on your part.
Slowly coming back from the ashes...February 3, 2016 at 10:03 am #267203Ditto!
Here are the official numbers for a VW Type 1:
Bias ply (with 1-2 persons) –
- Front – 16 psi (17 psi fully loaded; 18 psi after
Jan. 1973) - Rear – 24 psi (26 psi fully loaded; 29 psi after
Jan. 1973)
Radial –
- Front – 18 psi (both with 1-2 persons and fully
loaded) - Rear – 27 psi (both with 1-2 persons and fully
loaded; 29 psi after Jan. 1973)
A VW Beetle weighed about 1850 pounds. Surprisingly, about the
same as most TDr???s. So the original tire pressure spec is a good place to
start!Paul Mossberg
February 3, 2016 at 12:02 pm #267204I’m running 18 psi front – 24 psi rear and it’s been working really well.
Vicenç - (bee sense)
Pembroke Pines, FL
February 3, 2016 at 2:45 pm #267205Go up a bit for autoX. Like, 22 in front & 28 rear. Otherwise lower.
After I bought new tires the knuckleheads at the tire shop pumped like 35 lbs in all 4 of em. Thought my teeth were gonna shake out on the ride home.
