Home › Forums › MGTD Kit Cars › Chevy/Ford Kits › V8 in a TD?
- This topic has 6 replies, 4 voices, and was last updated 17 years, 2 months ago by
Geoffrey.
January 10, 2009 at 5:22 pm #232507
Does anyone know the largest engine that will fit in a TD replica?
I have a CMC kit and a 78 Pinto or MustangII chassis.
Any input would be great, thanks in advance!
January 13, 2009 at 2:37 am #238082Please, anybody?
January 13, 2009 at 12:43 pm #238083Hi Geoff
I don’t have any first hand info on V8 swaps in the TD replicas, but
I’ll throw in my two cents worth on engine swaps in general.
Measurement of physical sizes should be easy to obtain on the web. The
radiator size for a V8 isn’t the problem it used to be since you can
get very efficient 4 row and electric fans that can cool a V8. Steering
columns can be moved, exhaust can be custom made, and motor mounts can
be fabricated. So, in short, you could put in any engine that
physically fits. (Imagine a Flathead Ford in one.
).Physical size aside, is the frame on your TD strong enough?
Is the drive train strong enough? Mine isn’t. Borrowing from some
friends experiences, it’s real easy to mismatch components and end
chasing your tail trying to get things to keep from breaking.Again, just my 2 cents, it’s not something I think I would do. If you decide to do a V8, have fun and please post some pictures.
Ringo
January 13, 2009 at 2:21 pm #238084Great advice Ringo.
Adding a V8 is not just pop it in the car. These cars, especially the CMC front engine cars, do not have a frame designed to take the torque/hp of a V8.
Then there are fitment problems galore with the transmission, rear end and rear suspension change required to do this.
In the end, the car’s handling is terrible (nose heavy), it’s not a really nice drive or ride. I have a Fox Body Mustang road racer that weighs 2,400 pounds and has a mildly built 5.0L V8. It’s set up to handle the torque and horsepower, but is still a handful on the street.
Pink MG39826.600474537
January 14, 2009 at 9:45 am #238085Geoff,
Ran across this on Craigs List http://prescott.craigslist.org/cto/964902173.html
Just in case you can’t connect to the add, it;s an MG Hot Rod in what looks like a FiberFab body/chassis. it has a 350CU IN/45 HP engine in it. Doesn’t look to be too heavily modified. Does sound like he did some suspension work. Coincidentally he’s in Arizona!
Enjoy!
Rich
January 14, 2009 at 11:15 am #238086I’m sure there is more than just “some suspension work”. I’ll bet if you went to talk to the guy you’d see it’s been extremely modified. I’ve seen at least 10 of these cars over the years on Craig’s List, eBay, etc. They were primarily Drag Race oriented cars that give up ride and handling to go fast in a straight line.
To fit a V8 drivetrain, the firewall, floor, frame and rear suspension need to be HEAVILY modified requiring much special fabrication. You’d also be well served with a roll cage, fuel cell, racing seats and harnesses, not to mention larger brakes all around and a larger rear end too. Good luck if this is your plan…it’s not an easy job.
January 14, 2009 at 5:07 pm #238087Thanks to all who replied!!! This is just an idea I am mulling around. It seems that most people think it’s a bad idea, and their arguments are rather convincing.
It seemed like it would be a fun project to keep me occupied for a while with great rewards. But now it seems like it might be more like a long headache with great dispair!
I lone my TD the way it is, maybe I’ll get a model t kit someday and put a v8 in it instead!
Thanks again for everyone’s expertise and input. As always I appreciate it.
PS Rich thanks for the link, that car is hot!
check this one out- http://www.planetearthautos.com/show_veh.asp?veh=1242
