Just thought I’d pass on to the VW based TD folks that in the August issue of Hot VWs there is a great article of easy to do mods to the VW pedal assembly. Some of them are: different clucth shaft that attaches the clutch cable differently, beefing up the gas pedal and adding a grease fitting to the pedal assembly. Check it out.
