Home › Forums › General Discussion › where's the ign switch?
- This topic has 15 replies, 10 voices, and was last updated 11 years ago by
billnparts.
March 3, 2015 at 12:53 pm #235617
I am working on my wiring. I have accumulated all of the switches and connectors i need (maybe). I am looking at this wiring diag from Samba but I do not see the ign switch. Everything seems to run through the light switch? I wonder how you start the car. Are my eyes deceiving me?
March 3, 2015 at 1:02 pm #263496Found it. It seems to be part of the steering wheel wiring?
March 3, 2015 at 1:13 pm #263497Yes that is correct, on the beetle the ignition switch is part of the steering column. You should still be able to trace it and wire it how you will.
That actually looks like a Type 3 wiring diagram to me.Here is a link for a 69-71 beetle diagram.March 3, 2015 at 1:58 pm #263498Nobody wrote:Yes that is correct, on the beetle the ignition switch is part of the steering column. You should still be able to trace it and wire it how you will.That actually looks like a Type 3 wiring diagram to me.Here is a link for a 69-71 beetle diagram.Beginning with 1968 models. Prior to that, the ignition switch was located on the dashboard. Some kit build manuals recommend using a 1967 or earlier steering column, so you can more closely replicate the original TD.
Slowly coming back from the ashes...March 3, 2015 at 2:26 pm #263499Anonymous
InactiveNumbers on VW switches flasher unit etc. correspond to wiring diagram. You can follow diagram and wire switches from the numbers on the switch.
Pre 1968 steering columns are simple compared to later ones . But later ones have built in steering lock and dimmer switch, and ignition switch.
Kit wiring diagram is pretty good if you follow wires one at a time to were they go. VW Diagram is good if you wire the car with same color code VW used. Then it is easy to trouble shoot if there is a problem. Either way you wire it if you spend time wiring it good the first time you know were everything is.
A friend who is a pro mechanic , has own shop and has a Cobra that he built says you should not use crimp connectors but solder wiring connectors . He also says to use shrink tubing over the connectors. He did say soldering joints are harder to do but stated less problems with soldered connections.
i
March 3, 2015 at 4:44 pm #263500I built my Duchess in 1982. All connections I had to make were done with crimped connectors.
I’ve never had a loose connection.I’m not saying your mechanic is wrong. I fully agree soldered/imsulated connections are better.I’m just sayin’ I’m going on 33 years with no problemsPaul Mossberg
March 3, 2015 at 6:20 pm #263501I agree with Paul. Built in ’89.
"Drive Happy"March 3, 2015 at 6:46 pm #263502Look up the following on Amazon to get a crimper that makes tight connections:
S&G Tool Aid 18900 Professional Ratcheting Terminal Crimper
March 3, 2015 at 6:47 pm #263503Steve’s right. Failed crimp-ons are almost always because of poorly installed crimp-ons. You don’t want one of those 99 cent specials like those in the bin at the check-out counter of your local grocery store. Get a good tool. ….and practice on a few pieces of wire before you get upside down under your dash.
March 3, 2015 at 8:54 pm #263504Ditto on Eliza Jane. Ive never had a problem with crimp on connectors. I also removed my old VW teering colum and used an ignition switch from socal speed shop and mounted them on the dashes.
March 4, 2015 at 10:28 am #263505Thanks for all of the advice guys. I really appreciate it. I was planning on soldering my connections as much as possible. I will want some quick disconnects for some of the connections but by and large I will solder.
March 8, 2015 at 8:47 pm #263506Just got my new S&G Professional Ratcheting Terminal Crimpers. Works really slick and makes a very strong crimp. My old pair worked okay but have been used extensively and are um let’s say aged. Yeah…like me…Aged!
newkitman2015-03-08 20:48:05Allen Caron
"If one thing matters, everything matters" - from the book The ShackMarch 8, 2015 at 9:34 pm #263507Like a fine wine Allen!
March 8, 2015 at 9:42 pm #263508Here Here! I’ll raise a glass to that!
"If one thing matters, everything matters" - from the book The ShackMarch 9, 2015 at 4:04 am #263509I drink to anything! 😆
March 9, 2015 at 6:54 am #263510Rick, I like your thinking.
"Drive Happy" -
