Maybe Speedy Jim can help!
https://speedyjim.net/htm/spark.htm
good luck, however, this article is assuming a conventional distributor with points. A solid state distributor would usually have two wire leads that go to either side of the coil. Regardless, Power to the coil goes from battery to ignition switch to coil. May or may not have a fuse in line, depending on the builder.
Gregg
This reply was modified 1 year, 5 months ago by
Gregg Strain.
