Home › Forums › MGTD Kit Cars › VW Based Kits › Wiring Harness Circuit Question
- This topic has 5 replies, 2 voices, and was last updated 15 years, 7 months ago by
November 22, 2010 at 12:21 pm #233240
On the VW based wiring harnesses. How do you count how many circuits you have? By the number of fuses or by the types of equipment they power? Have to order a kit and don’t know if I need an 8 or 12 circuit kit.
Thanks in advance for the help.
"If one thing matters, everything matters" - from the book The ShackNovember 22, 2010 at 12:35 pm #242992Well, each fuse protects one circuit.
It’s more that the equipment will determine the number of circuits you need.
Have I sent you my Duchess schematics?
November 22, 2010 at 2:36 pm #242993Yep I have them and that’s why I asked the question. I guess an 8 circuit will do the trick. Is that how you read it Paul?
"If one thing matters, everything matters" - from the book The ShackNovember 22, 2010 at 10:32 pm #242994Yes, I think you’ll be fine with eight.
Pretty sure the VW Duchess has only six.
November 22, 2010 at 11:12 pm #242995Paul,
The Duchess does have 6 but I’m going to go with the 8 so I can have room if I want to add the Air Horn and Defroster. Do you have a defroster in your Duchess?Allen Caron
"If one thing matters, everything matters" - from the book The ShackNovember 22, 2010 at 11:53 pm #242996Yes I do. But it is just a blower that moves air across the windshield from four vents along the base.
I run the “normal” VW forced hot air into the car through ducts under the seat. the passenger compartment is so small that it really does get too hot if you have the heat all the way on. The cable control to the heater boxes is hooked up.
The air moved by the defroster blower will not melt ice. Btu it does keep the windshield fog free.
