Home › Forums › MGTD Kit Cars › VW Based Kits › wiring help on my migi
- This topic has 5 replies, 5 voices, and was last updated 15 years, 5 months ago by
Daniel Fore.
October 1, 2010 at 7:36 pm #233150
check my photo gallery out and help me find out what wiring
this is is it a normal VW wiring or the kit wiring its a
mess i cant figure out what is what
October 1, 2010 at 8:08 pm #242446Junkman, The wiring looks to me like it’s designed by the kit manufacturer. It looks simular to my VW based car except mine is under the dash on the driver side. The junction block serves as a convenient method to connect wires coming from different directions where it may not be practical to run one continous wire the entire distance. The fuse block should have a fuse for each circuit such as lights,wipers,turn signals ,etc. It does not look like VW wiring to me, though the circuits may be close to the same thing. You can use a test light to determine what wire goes to what accessory.
October 2, 2010 at 8:20 pm #242447Are you replacing or trying to salvage If you havent started yet, Start over. wire wire everywhere where it goes Im not aware. There have been a couple good posts I think one of the best was in 2008 do a search for wireing. also there was a great article in kitcar mag about 2 months ago about a couple new products to help with this. if you need a vw diagram let me know. based on my limited experience these 2 pieces don’t look vw.
October 2, 2010 at 9:01 pm #242448I have excellent VW – TD wiring diagrams from Classic Roadsters.
Send me a private message if you want them
October 2, 2010 at 11:19 pm #242449I can vouch for Paul’s Duchess wiring diagrams. I’m building a new kit and his are far and above what my assembly manual has.
"If one thing matters, everything matters" - from the book The ShackOctober 3, 2010 at 8:27 am #242450allen and paul thanks for all ya’lls help I will send you a
pm pauli really could use some help cuz my wiring looks
like a nest
