Home › Forums › General Discussion › A 4 gallon minimum purchase?
- This topic has 31 replies, 9 voices, and was last updated 13 years, 4 months ago by
greg press.
September 19, 2012 at 9:56 pm #234318
I’m not one to go batty about ethanol blended gas & think it’s gonna KILL ALL OUR ENGINES RIGHT NOW, but this is getting a little ridiculous. Here’s noted liberal Kevin Drum agreeing with Jim Sensenbrenner about a proposed EPA mandate that just kinda proves the main point of every (God bless ’em all) right-wing conspiracy theorist over at the SOC.
And here’s me agreeing with them both (though I don’t believe E-15 would literally set my lawnmower aflame). C’mon, ADM, Corn Refiners Assn’ & all you midwestern moochers: Enough already with the corn mash.
September 20, 2012 at 6:43 am #251884At our local FASTRAC gas station , you can now get the 93 octane that has NO ethanol
September 20, 2012 at 9:31 pm #251885braggart.
September 21, 2012 at 6:50 am #251886Wish all stations would have this, I treat all my gas with sta-bil , that has ethanol. One of the worse parts of ethanol is that it draws water to your gas tank and not good for the carburator.
September 21, 2012 at 10:51 am #251887Old Cars Weekly has published a good series of articles about ethanol.
Start with this one:There are links within the article to prior Q&A columns that dealt with ethanol.And check out the pictures in this column, from an owner who claims the corrosion was caused by E-10 fuel:PMOSSBERG2012-09-21 10:52:00
September 21, 2012 at 12:25 pm #251888Good info Paul.. thxz
September 22, 2012 at 7:28 am #251889As i’m reading all of this i’m still confused are most of you using 10% ethanol gas or not using it. Are you adding additives or not .I was talking to a car guy who owns a plymouth roadrunner who never burns it ,but it limits where he goes he said ethanol burns hotter.What octane do you guys burn, ethanol and non ethanol .Should i put an additave in if so how often and what one do i use. I’ve replaced gas lines from filter to carb.Should i replace line from tank to filter . I had the old braded cloth type.
September 22, 2012 at 8:09 am #251890
Yes I would love to hear what eveyone is burning also ..and also what burns hotter ..September 22, 2012 at 8:04 pm #251891We have a few stations around here that sell nonethenal gasoline. So Thats what I use in my TD.
September 22, 2012 at 8:12 pm #251892smitty thxz
yes we do also here on oak islandwhat octane do you use?September 22, 2012 at 9:11 pm #251893I use “pure gas” in my TD and in all my small engined yard equipment. I like this site and it is 100% accurate in my “neck of the woods”. http://pure-gas.org/index.jsp?stateprov=NC
Royal2012-09-22 21:46:17September 22, 2012 at 10:33 pm #251894Thanks Roy. Great resource.
Apparently, the way the site is built, you can’t link to a specific state.
The home page is at: http://pure-gas.org/
September 23, 2012 at 4:10 am #251895To think that once, in the early 80’s, I was considered a cumpeter guru? Today I have no clue why or how these things work. I guess you do have to start from the home page. Thanks.
September 23, 2012 at 10:11 am #251896Thx guys.. good info
September 23, 2012 at 11:09 am #251897There is a station about a mile from me that sells only pure gas…87 or 98 octane. I knew about them because there are a lot of dune buggys that go there for their gas and I started going there with the Ghia. Most of the stations locally sell there gas with the note “may contain up to 10% ethanol.” On the corner about 1/4 mile there is a Shell station that has one pump only for E85 (corn squeezins). Haven’t noticed that pump being used in a couple of months. Wonder if the water separates from the corn after sitting in the tank for a while?
"If one thing matters, everything matters" - from the book The ShackSeptember 23, 2012 at 11:42 am #251898I checked that pure gas list. Nothing near me around Balto–looks like mostly Eastern Shore.
Still. I think y’all E-10 worriers are worrying a bit too much. We’re near a decade past the MTBE era now & yet to see huge problems with old air cooled engines–other than the normal grenading you always see when they punch Type 1’s out over 2.2 liters and run them at 6,000 RPM.
You’re running a 1915? A 1600 with two Solexes? And doing 4,000 miles a year?
Even with E-10, the motor will probably outlive you.
September 23, 2012 at 12:00 pm #251899Yeh ED your probably right. I like to use pure gas because I get better mileage and it stores a little longer.
September 23, 2012 at 12:02 pm #251900Roger that, Smitty. I’d run it too, if available.
September 23, 2012 at 12:04 pm #251901Ed, did you notice that you can add stations if you know of any near you? What bothers me most about ethanol is what I have seen it do to rubber hoses (like the fuel line hoses). I don’t think that i would put it in a fiberglass fuel tank either based upon experience. In other words, my concern is not so much engine life as these other considerations but I’m not smart enough to know about engine life. By me, it seems that the no-name brand X stations are more likely to carry pure gas.
September 23, 2012 at 12:28 pm #251902My thinking is it won’t hurt metal lines and rubber hoses are OLD, so you’ve replaced them already with neoprene or whatever new fuel lines are made from.
Right? ‘Cause it costs like $10 and takes a half hour. Right?
And I don’t know from fiberglass fuel tanks. Is that even legal? But whatever your tank is made out of, I think there are several commercially available tank liner products that should seal them up and make them fuel worthy.
In the 50s, hot rodders were always and forever converting to pure alcohol to go faster. This ain’t rocket science.
September 23, 2012 at 12:48 pm #251903“My thinking is it won’t hurt metal lines and rubber hoses are OLD, so you’ve replaced them already with neoprene or whatever new fuel lines are made from.”
I have replaced my hoses, but I don’t know what the new hoses are made of. I do know that they were some sort of braided fabric on the outside like the original VW hoses.Re Fiberglass fuel tanks, I don’t know if they are legal. I do know that they were used on some boats but most/many/all have been replaced because the fuel attacked them.September 23, 2012 at 3:37 pm #251904
..I use pure gas at my nearest station and as Royal sez at the no-name brand X station .They only have 93 Octane..while 7 miles away they have 87.. should I just be using 87?. thxzSeptember 23, 2012 at 6:22 pm #251905It’s only in the last couple of years that the rubber industry has come to address the construction of their hoses as it relates to the ethanol problem. The first generation of Gates’ “barricade” hose had problems with deterioration of its own. They now seem to have the problem solved as far as the hoses falling apart with constant ethanol exposure. Unfortunately, a lot of garages turn up their noses at stocking another line of hose or a more expensive line of hose and they simply another piece of junk back on your car. Those of us who do their own work can put on what’s right. Those who pay to have their work done, watch out.
http://www.gates.com/brochure.cfm?brochure=12468&location_id=541
"Drive Happy"September 23, 2012 at 9:46 pm #251906John, with a regular VW engine 87 octane should be just fine.
September 23, 2012 at 10:04 pm #251907Thx ed ..dumb question other than my pocket book is the 93 ok?
