Home › Forums › MGTD Kit Cars › Chevy/Ford Kits › Accelerator Cable
- This topic has 9 replies, 7 voices, and was last updated 13 years, 10 months ago by
DonsMG.
April 23, 2012 at 8:01 pm #234108
The FiberFab Ford kit I am building didn’t come with an accelerator cable so I bought a new one for a ’78 Pinto and installed it according to the kit instruction manual. It’s only 24″ long and even with the best routing the bends are quite tight. I worry that it might bind some day and take me quickly where I don’t want to go. Does anyone know of a longer cable that would be an easy replacement? The cable I used is a Pioneer CA8447.
Here is a photo of the cable installed.Don Loveless
Ford Pinto Fiberfab
Rochester, MIApril 23, 2012 at 9:43 pm #250220Don I don’t know part numbers for a longer cable but i have always had my best luck NAPA parts stores they seem to be more in tune with odd stuff more so than outher places .. GOOD LUCK Dan
April 24, 2012 at 12:53 am #250221Don you might want to post your question with the pinto guys?
they are a help full bunch of nuts
TDREPLICA Map
April 24, 2012 at 5:42 am #250222Try getting a cable for a full size ford same year 78 with a Sraight 6.The cable should longer because the carb will be further from the firewall.
April 25, 2012 at 8:43 am #250223My engine runs an ’87 truck number. I forget the exact application, but
it fit the pedal and reached the carb. Spend a sunny afternoonin a salvage yard.Bill Ascheman
"Drive Happy"April 25, 2012 at 8:48 am #250224I just noticed that your cable brack looks unmodified. I recall the initial
installation instructions called for notching the bracket and changingthe angle that the cable approaches the throttle linkage. The factoryPinto cable had worked fine on that setup for years until I upgradedther engine.Bill Ascheman
"Drive Happy"April 25, 2012 at 8:56 pm #250225Don, Just checked mine and it’s not much different. I lubed it a few years ago and haven’t had any problems. One time the bracket shifted and it caused a bind at the linkage, but the cable has had no problems.
April 26, 2012 at 8:20 am #250226Here is the link to the Download Manual section: Fiberfab: Pinto section
on the modification of that bracket.Bill Ascheman
"Drive Happy"April 26, 2012 at 9:11 am #250227Don because of the tight turns make sure the cable is well lubed. I went with an after market universal cable and cut it to length. You want free movement on this part with the right return spring.
April 28, 2012 at 2:11 pm #250228Thanks guys for the helpful input.
I did originally modify the bracket by cutting and bending as the assembly manual indicated. I welded the cut and painted the bracket so the modification doesn’t show much. If unmodified I think the cable would have run into the side of the master cylinder.Yesterday I lubed the cable and it’s much freer than I expected it could be. I suspect it will be OK but I am going to continue to look for a longer cable. I’ll post if I find one that works.Don Loveless
Ford Pinto Fiberfab
Rochester, MI -
