Home › Forums › MGTD Kit Cars › Chevy/Ford Kits › BCW Dash Project
- This topic has 16 replies, 9 voices, and was last updated 15 years, 11 months ago by
Mark Hendrickson.
March 30, 2010 at 6:50 pm #232930
I have finally got my dash finished with a glove box and a almost flat steering wheel.
March 30, 2010 at 8:30 pm #240870
That looks really sweet, Larry!March 30, 2010 at 11:31 pm #240871Very Nice!
March 31, 2010 at 9:14 am #240872Very nice work
March 31, 2010 at 12:56 pm #240873Great lookin dash!!! Shoot I thought I was about done on Audrey… Got me thinkin now.. Maybe next winter..Montie
March 31, 2010 at 5:58 pm #240874Larry
that dash looks great and I love the color of the grain . what color stain did you use?
DanMarch 31, 2010 at 10:23 pm #240875Thanks for all the nice comments.The wood came from a home improvement store. 2 x 4 feet so I had enough for two in case I goofed up the first time. It’s plywood with one good side,not expensive at all.The edges were a challange as I had not used a router before. The trim on the top edge is ”chrome” fender welt.The glove box door trim is window trim from a 60’s GM car with the rubber that contacted the glass removed. Ringo suggested this and a local glass shop had a piece left over from years ago. I was able to use the door that I cut out so the grain pattern is not different from the dash itself.The is finished with MinWax ”Early American” #230,rubbed on with a soft cloth.
April 1, 2010 at 8:59 am #240876Larry,
Looks Great! Another winter project well done.
April 1, 2010 at 9:21 pm #240877Larry,
Who did you buy the steering wheel from?
April 1, 2010 at 10:43 pm #240878Paul, I knew that question was going to come up, just didn’t know when.
It was on my 70 CHEV truck when I bought the truck six years ago.It was about four inch dish, too high so I replaced it with a two inch dish that I already had. The Grant wheel that was on the BCW when I got it was too in my face as well since the horn wiring was in the adapter under the wheel.I cut the wheel between each spoke with a hacksaw, sawing toward the center hole. I laid the wheel upside down on the workbench and pressed the spokes down almost flat. The spokes overlapped each other so I then used the saw to shorten each spoke so they would meet but not overlap.Then I drilled the spokes to match the holes in the adaptor. The horn button covers everything giving a finished appearance. Just another of my cheap inventions but it moved the wheel to a more comfortable position.
April 2, 2010 at 9:35 am #240879Ah, so you’re telling us you’ll modify dished steering wheels for us! Nice of you to offer! Thanks Larry!
I have a flat steering wheel on my Duchess. I asked because there was a lot of discussion here a couple months ago about here to find zero dish steering wheels.
Would you post a picture of the center hub with the horn button removed?
Must be tough to drive the Chevy truck with no steering wheel!
PMOSSBERG40270.4003356481
April 2, 2010 at 10:05 pm #240880Here is a drawing of the steering wheel . Hope this helps.
I would not try this with a new wheel,too expensive to risk.
April 2, 2010 at 10:17 pm #240881To continue on the steering wheel project, I did the same modification to a 74 Datson wheel a while back. It was a 15” wheel and really felt good as far as size. You can see it on the white car in my gallery.
April 15, 2010 at 5:06 pm #240882Larry:
Is there a trick to hooking up the speedometer cable? I wanted to have a look at the wiring to see if I would tackle a job like you did. There wasn’t enough slack, and the speedo cable was keeping me from seeing how bad a job it would be. I decided it would be a much later project and put it back together. Now the speedo doesn’t work.
April 15, 2010 at 7:53 pm #240883Gene, I cannot help on the cable. Mark had already converted my car to the electronic type. It has no cable ,just wires.
It was nice of you to offer to check out the car ,it could save someone a long drive or a big dissappointment.
April 15, 2010 at 8:54 pm #240884Gene / Larry—- on my speedometer cable it had an adaptor that fit to the speedometer screw on head — to the GM cable and it would not work– there is a clip to hold them together very easy to put in but not stay in, it lost temper over the years and would not hold the cable end and adaptor to each other, it is a GM clip —- but not being able to get to a dealership on a Saturday evening I did the next best thing
I cut a slit in the cable end and clamped it to the adapter 2 years now no trouble
—Dan, — Good luck– PS just got back from the first car show in Pigeon Forge 4 miles of all types of cars on both sides of the road and this is only Thursday 2 days to go
Dan R40284.7231944444April 16, 2010 at 10:46 am #240885Looks great Larry. I guess Murf approves too! Now you can fit a couple bones in the glove box!
Now for some comfortable cruising!
