Home › Forums › MGTD Kit Cars › VW Based Kits › BRAKES LOCK UP
- This topic has 5 replies, 5 voices, and was last updated 8 years, 10 months ago by
Bob.
May 2, 2017 at 1:52 am #303541
My right front brake on my 68 VW frame locks up when the brakes are applied. Anybody know of a good reference for trouble shooting brake problems or have any thoughts on where to start..?
May 2, 2017 at 8:18 am #303542Scott
Do you have drums or disks that are locking up?David B Dixon
SabineMay 2, 2017 at 8:39 am #303543There are many informative and helpful videos on YouTube. I just search the subject I want to learn about. For your situation, I entered “air cooled vw brake” and it came up with over 5 different people showing how to do everything from inspecting to actually replacing the brakes. You can also google(or in my case Bing) “air cooled vw brake” and, again many hits. I’ve done this for everything I’ve done on my cars. There are are two indispensable books you should get. One is How to Keep Your VW Alive and the Haynes VW and Karmann Ghia repair manuals both available through Amazon.com or possibly your local bookstore. Using all three of these resources, you can do just about any work. I recommend reading and watching each procedure at the same time.
Good Luck and keep us posted…
Amor Conquista Todo
May 2, 2017 at 12:26 pm #303546Rob and Dave’s Aircooled Pages are a great resource too:
Their brakes pages are indexed here:
http://www.vw-resource.com/brakeslinks.html
Some simple first steps:
Visual inspection – looking for things like fluid leaks, soft brake lines. Bad? Fix it. Good?
Brake pedal – Is it firm? If sot, likely need to bleed the brakes.
If the above are good, and you have drum brakes at all four corners, you may just need to adjust the brakes. Pretty easy to do. Check the Rob & Dave pages or the resources mentioned in other responses.
If you have front disks and rear drums, the next thing I’d check is the proportioning valve that should have been installed when the front was converted to disc.
May 3, 2017 at 1:11 am #303550Thanks for the references and the advice..
Being a 68, I just assumed they were drum brakes on all 4’s, but I guess I better pull a wheel and check first.. Then, I think
I need to start by looking at some of the references or Youtube and as Paul suggests learn how to adjust the breaks before I start pulling and replacing things..
Scott
May 3, 2017 at 5:13 am #303551Mine were filthy with a tendency to lockup easily, and one or two (forget now) needed adjusting too.
Brake cleaner on the pads and drums (avoid hub bearings) and a screwdriver to turn the star-wheel (adjusters) is all that it took to fix it. Fairly simple thing, DIY job, just not something you want to get wrong either so I won’t try to explain it.
This reply was modified 8 years, 10 months ago by
Bob.
