breather hose
Home › Forums › General Discussion › breather hose
  • #233861
    greg press
    @greg-press
    one end of hose goes into oil cap  does other end connect to any thing or does it lay there?
    #248186
    Dan Rosa
    @dan-r
     Hi Greg, before we had air pollution controlled   cars they had road draft vent that went from the oil cap down toward the road an angle cut pipe using the forward movement of the car to create a vacuum past he pipe and lower the crank case pressure in the engine block. some time in the late 60’s crank case vents went to the air cleaners the be burnt and to lower crank case pressure at the same time. different from the PVC vent that goes to a port under the carburetor check the under or side of your air cleaner for 1/2 inch [about] male pipe end .  good luck  Dan
    #248187
    Royal
    @royal
    My guess is that you are talking about the hose that goes from the oil filler to the air breather (filter).  Usually there is a small nipple on the bottom of the air filter that it just pushes on to.
    #248188
    mine goes to the passenger side wheel well
    #248189
    Richard Wobby
    @richard-wobby
    after confering with hulmet i would see that it attaches
    to the air cleaner
