Broken Fuel Line
Home Forums MGTD Kit Cars Broken Fuel Line
  • #307607
    Lee Komich
    @copterpilot
    Has anyone replaced the main fuel line?  Mine is broken at the point where it comes out of the pan…hard to get to.  The first question is does the fuel tank need to be removed?
    #307609
    crash55
    @crash55
    you should be able to leave the tank in .  Check this link for more info https://www.thesamba.com/vw/forum/viewtopic.php?t=380724  it goes through the whole job doable if you take your time & do not short cut keep us posted it took me awhile to get the link but it pretty much covers it
    • This reply was modified 4 years, 10 months ago by crash55.
    #307614
    I did not replace my in-tunnel line but when I installed the Subaru engine I ran new fuel injection hard lines front to back—fuel and return. Since I was not taking the body off the pan I ran the lines through the interior of the car low on the passenger side of the tunnel.
    Shocking? Well, actually, that is how Subaru did it:
    I ripped out the Legacy hard lines and laid them down alongside the MG to check for length and shape.
    My car already had the positive battery cable running inside the cockpit along the tunnel:
    So I just added some more…
    With the carpet on installed you’d never know they’re there. I repurposed the original fuel line as a vent and put the Suby’s original charcoal filter and catch valve on it.
