bulbs for front fender bullet lights
Home Forums General Discussion bulbs for front fender bullet lights
  • #233306
    Russell Boulanger
    @russlb
    I have a dual filament bulb looks like a 1157 or the old 1034 except the alignment tabs are not staggered they are both low on the bulb base there are no numbers on my existing bulbs PMOSSBERG40554.9828240741
    #243393
    Larry Murphy
    @larry-murphy
     My father-in-law had some accessory  lights about 30 years ago that used bulbs of the type you describe. I’ve got a feeling that they maybe hard to find now. Would it be possible to change the sockets to use the staggerd tab bulb?
    #243394
    Russell Boulanger
    @russlb
    these lights came with the MIGI kit in the early 80’s
    what I found out so far is it’s a S8 bayonet base non indexing dual contact dual filament just have come up with a part number yet
    #243395
    Larry Murphy
    @larry-murphy
     I found one of the old lights. The bulb # was1126. The base was marked ”top” to show which way to insert it in the socket, The # 6 was also stamped on it  so it may be a 6 volt bulb. We changed the car these lights were on to 12 volts but that may have been after we removed the lights that used this bulb.Hope this is helpful.
    #243396
    mike
    @schweppes
    try bulbs.com
    #243397
    Congrat’s schweppes!
    You’ve already moved from asking questions, to providing answers
    #243398
    mike
    @schweppes
    I purchased the bulbs from them. As the shipping cost was more than the bulb, i ended up buying about 6 of them.
