Carpet from MG Magic
Home Forums MGTD Kit Cars VW Based Kits Carpet from MG Magic
  • #235436
    Harry Lewis
    @spike-lewis
    Hi, Going to replace the previous owners custom indoor outdoor carpeting. It is held in place with many Phillips head screws. Is the carpet set from MG Magic held in place with screws also?
    Thank,
    Spike
    #261813
    newkitman
    @newkitman
    I purchased my carpet set from MG Magic. The carpet is attached using 3M spray carpet glue. I don’t recall any screws either being used or recommended. My TD is a later Fiberfab/CMC TD.
    #261814
    greg press
    @greg-press
    Carpet tape works very well .
    #261815
    ray10
    @ray10
     I replaced the carpet pad also. I glued the pad down with 3M spray  ,the rest was put in with screws .
    TDREPLICA Map
    #261816
    billnparts
    @billnparts
    When I replaced my carpet over the summer, some of the panels I put in place with snaps. Easy in, easy out.
    "Drive Happy"
    #261817
    newkitman
    @newkitman
    Spike,
    My assembly manual says to attach the carpet with carpet glue. The portion that fits around the doors gets glued to some cardboard and the cardboard/carpeted panel gets screwed in around the door openings. I forgot about that part because that’s the one part of my carpet I haven’t installed yet. I did secure the upper corner of the rear compartment area with carpet glue and one self-tapping screw and finish washer.
    #261818
    Anonymous
    Inactive
    I used screws, gets wet take them out and dry, replace.  Used stainless with the round, raised washers.  Looks nice.  dennis p
