Home › Forums › MGTD Kit Cars › My Project › convertible top
- This topic has 10 replies, 6 voices, and was last updated 15 years, 1 month ago by
mike.
June 22, 2010 at 8:03 pm #233036
We have a Daytona Migi MGTD I think a 1953 version. We need a convertible top to replace the original. It’s a two pole type. We have been told that the MGTD convertible tops available may not fit the Migi. Any suggestions? This is just about the last thing we need to make the car roadworthy (we’re in Seattle, you know with the rain and all). Any suggestions would be appreciated.
June 22, 2010 at 8:48 pm #241675Try a boat top maker. TD tops are more like Bimini tops than modern car convertible tops.
June 22, 2010 at 9:50 pm #241676Hi Ron Welcome to our little group a new top can be bought from MG Magic in Hollywood Fl. phone 954 680 2010…. lots of mg kit stuff …Good luck Dan
June 22, 2010 at 9:50 pm #241677I have a factory built London Roadster TD replica that as far as I can determine uses the same body as the Daytona MIGI. I replaced the top with one that fits an original MG with a two bow top. In order to make it work, I had to cut 2” off each end of the rear top bow.If I had not shortened the bow the top would not have been long enough to reach the windshield. I still have enough head room because the top is not lowered where it passes over the driver’s head ,it is lower in the area behind the seat.Also ,I am only 5’8” tall.Iordered it off the internet from Convertible Top Guys.Their price is just under $300.I have been very happy with it and will go this route again ,it’s a much better top than the ”custom made ”top on my BCW TD replica. Just remember, if you cannot make it work, you are stuck with it.You can see it on the yellow MG in my members photo gallery. Larry Murphy40351.9156944444
February 15, 2011 at 6:38 am #241678my fiberfab top has been in storage and in nice shape, however it will not come close to fitting(4inches short). the snaps line up so it appears to be original to the car. does vinyl shrink that much? i have it snapped with the bows loose but cant push it up . any ideas?
February 15, 2011 at 9:18 am #241679Are the bows the correct height for the top? I know the top material shrinks over time but 4” seems a little much.Do you have the front bow slide positioned as low as it will go on the rear bow? Last,is the windshield mounted at the correct angle? By tilting the windshield to the rear of the car you can get the two closer together but if you tilt it too far it will not suit the design of the car.
I have heard of hanging the top over a table and hanging weights to the front and rear of the top and soaking with water over a period of time to stretch the material.
Let us know how it turns out.
February 15, 2011 at 4:34 pm #241680yes larry ,the bows were attached and in a zippered covering with the top. im thinking some summer weather might make a difference. surely im not the only one to have this problem.
February 15, 2011 at 6:53 pm #241681Yeah, hanging weights from the edges will work wonders, esp if you put it the warmest spot in the house. If you rush it by putting too much heat (like a heat gun…) it might rip or wrinkle. Ask me how I know
You can use a hair dryer and use it sparringly over a long time (think weeks, not days) and keep both sides hydrated. A couple of weeks will tell you if it’ll stretch back out.
Ron, boat top shops are the first places I’d try.
Ringo40589.7886689815
February 17, 2011 at 5:38 pm #241682ok. top is on.
a couple warm days of sun and pushing the loose bows up from the bottom and pulling the bows together with a cargo strap . didnt know vinyl would stretch that muchFebruary 17, 2011 at 10:11 pm #241683Good job!!! Just goes to show that patience pays dividends. Glad it worked out for you.
What’s that animal in the background?
February 18, 2011 at 4:55 pm #241684that critter is a concrete deer . the real ones come at night and have dinner with him
