Home › Forums › MGTD Kit Cars › VW Based Kits › Did I Pay Too Much?
- This topic has 13 replies, 8 voices, and was last updated 12 years, 8 months ago by
KentT.
June 4, 2013 at 10:25 am #234719
My wife’s grandfather built his Classic Roadsters Duchess VW based kit off of a ’71 VW Beetle in 1982 for my wife’s aunt. When his wife figured out that it was fiberglass with a front mounted gas tank, she put the brakes on it being driven by her daughter. After only 1500 miles were put on it, it was left to sit in a garage until now. It was last started about 10 years ago. The seats are stained with mold but complete. A leak in the garage lead to a hole in the drivers side floor (yet the undercarriage looks like it was never driven :lol:). The brakes go to the floor and, so far, I haven’t been able to get it to start. The tires have been flat for almost a decade. The body is close to perfect and the chrome only needs some polishing to be perfect. The side curtains are dirty but salvageable. The top is like new. He wanted $1000 for it and I didn’t want to squabble with family over money, so I took it at that price. Did I pay to much for this project?
BIGBAND39 2013-06-04 10:26:16 June 4, 2013 at 10:32 am #256321Let’s put it this way. A good-running dual-port VW motor (which this one likely has) is worth what you paid for the whole car…
Or, a new chrome grille shell is about $900, without the chrome slats which are about $200 extra. A new top and side curtains are $600. Etc, etc, etc.You did well…Early FF TDr on 69 VW pan
Slowly coming back from the ashes...June 4, 2013 at 10:37 am #256322I agree with Kent.
You might have saved a few bucks. But $1,000 isn’t excessive.And Kent is right about the parts values! So even if you give up on the car, you’ll get your money back.PMOSSBERG2013-06-04 10:39:28
June 4, 2013 at 10:53 am #256323Little bleach on the seats, followed by some armor-all.
Empty the fuel tank and clean it. Water’s fine–it’ll dry, but I’d use about two cans of starter fluid. Spray it in and dump it out. It evaporates in about two minutes.See other post re getting her started. This won’t take all that much. Replace the coil. New points and condenser. Probably new plug wires. Pull the plugs and see, clean if dirty. Spray penetrating oil in the plug holes and put them back in. Crank the engine over with the starter, or by hand. Change the oil.Drain the brake fluid reservoir, refill, drain again. Then replace the soft brake lines, wheel (slave) cylinders, and brake shoes. Refill with new fluid and bleed until you get a nice high pedal. If it won’t come up all the way check the adjusting screw on your brake rod. Mine needed a half turn or so.Replace the tires.Get some self-tapping sheet metal screws and some sheet steel and patch your floor hole, then put some carpet over that.You’ll probably have electrical gremlins but you should be on your way. Drive on! Buy a new floor pan so you’ll have something fun to do next winter.edsnova2013-06-04 10:55:56
June 4, 2013 at 11:58 am #256324If I lived just a bit closer, I would give you $1200 and be glad to take your car for parts. A bargain. Smile, be happy!
June 4, 2013 at 4:31 pm #256325nice find watch my thread (I’m ready). rockauto has almost all the brake parts. if your hoses are bad get stainless hoses you’ll get a much firmer pedal keep us posted on your progress
June 4, 2013 at 7:41 pm #256326If what you say is true, that’s going to clean up nice.
I think you did well.
Happy motoring.Bill Ascheman
"Drive Happy"June 4, 2013 at 9:08 pm #256327There goes Roy again. Always ready to help out a friend!
June 23, 2013 at 2:39 pm #256328After a month of night of getting a few hours at a time at the garage, I finally was able to get my Duchess out on the road! Here is what she looks like now in comparison to the sad garage pick I posted earlier. She still needs replacement tires, the rear suspension feels loose, floor patching, and I want to find some chrome trim rings and baby moons for the rims. Still, not bad for the money. 😀
June 23, 2013 at 2:47 pm #256329There ya go!
June 23, 2013 at 5:12 pm #256330Car looks great!
Back to your initial question…You did not over pay!
June 23, 2013 at 5:28 pm #256331My offer still stands. Looking good.
June 24, 2013 at 2:35 am #256332That’s a real beauty, Jonathan. I’d say you owe grandpa a ride, if nothing else.
1981 Lafer TI
1600 cc Type 1 engineJune 24, 2013 at 7:56 am #256333It cleaned up quite nicely!
