Door Installation Question
Home Forums MGTD Kit Cars VW Based Kits Door Installation Question
  • #235814
    newkitman
    @newkitman
    MY TDr currently has the doors taped on and the holes in the body drilled for the hinges. Would you recommend a small metal plate on the inside to take the wear-and-tear of door opening and closing or just leave it as is. BTW…had to cut two holes each side to access the hinge nuts. Carpet will cover tham easily but it sure make access to the nuts a lot easier. 🙂
    #265258
    Allen,
    Yes. Either that, or a couple large fender washers on the inside of the door and door jam bolts.
    Cutting access holes is standard operating procedure.
    #265259
    ray10
    @ray10
    Allen yes ,I put in a aluminum bar in door jam then
    fiberglassed
    it in. 😉
    ray102015-07-26 19:10:21
    TDREPLICA Map
    #265260
    crash55
    @crash55
    I’ll go with the fender washers it would not hurt to spread the stress out
    #265261
    billnparts
    @billnparts
    I originally cut holes to access the nuts but later found that they could be reached from inside the rear wheelwell.
    "Drive Happy"
