Ed,, i had the same trouble, after playing with the hinges ,and that did not work the way i wanted ..I took some oak put it inside the fiber glass doors cut to the bend i needed to twist the door ,,only needed 3/8 of an inch to twist it back to flush with the body. that is when i did the inside of the doors also ,with some oak trim . just a note i did this in the heat of summer,i don’t think this should be done in a cold time if year ,the fiber glass will not bend, but it will crack in the cold . GOOD LUCK Dan
