Home › Forums › MGTD Kit Cars › VW Based Kits › Duchess Body Pull
- This topic has 35 replies, 14 voices, and was last updated 11 years, 11 months ago by
July 27, 2013 at 9:18 am #256542
A little more progress: We started it up (momentarily) last night.
We got enough wiring done to where it should start, and spraying a
little starting fluid in the carburetor got it to fire and run for a few
seconds (there is zero gas in the tank).
A few minutes later I hit the key for just a second to check the
warning light, and it immediately fired again and ran for a second off
of left-over starting fluid. Not bad for the first time in 3 years the
engine has been turned over. It was the first time I saw my wife get
excited about this car project.Now I have to get turn signals,
warning light, horn, headlights, wipers, and fog lights working. I
have built and played with radios and read electronic schematics for
years – but for some reason, the car wiring freaks me out! I think I
will try to find some info on what the various contacts are on the
gauges, and maybe that will help.July 27, 2013 at 11:31 am #256543don’t think of wiring as 1 big system. do one circuit at a time,you’ll be fine
July 27, 2013 at 7:57 pm #256544Anonymous
InactiveBuild manuals give wiring info. Also VW wiring diagrams give listing of were wires connect to the proper posts of components. The posts of VW switches relays are numbered. If you follow diagram wire will lead to point of contact on switch, relay or component. Wiring diagram has wi
July 27, 2013 at 11:28 pm #256545Classic Roadsters Ltd. schematics are excellent.
They are available in our “Download Manuals” section.Paul Mossberg
July 28, 2013 at 7:55 am #256546Thanks guys – I’ve downloaded all the manuals for Classic Roadsters and VW. And for the other replicas as well. One problem I am having is that the color code was not adhered to all that closely in this car. In the worst case example, one spliced wire changes color 3 times before it gets to it’s final destination. In another case, the Classic Roadsters manual says to hook the light blue wire to the Voltage Regulator – and I have no light blue wires anywhere. Sorry to sound like I am whining – this is just new to me, and you know the old dog and new tricks saying. I’ll get it eventually, and I think the one circuit at a time approach will work for me. I’m thinking about putting extra long leads on the probes to my multimeter, so I can identify the wires from end to end.
July 28, 2013 at 8:08 am #256547No need to cut your multimeter lines. Get some alligator clips and make a pair of jumpers long enough to reach from the furthest part of the car to the fuse box.
July 28, 2013 at 9:01 am #256548While you’re there, might want to think about ripping out any wire that’s spliced more than twice and replacing with with a new wire. Could save some headache later on.
August 1, 2013 at 6:43 pm #256549All good suggestions. Monday we got the gas tank hooked up and put gas in it, and the car starts fine. It has been a busy week, and it looks like it will be next Monday before I can get back to it.
April 14, 2014 at 2:32 pm #256550what gauge pans did you go with and are you still happy with that decision? I am getting ready to do mine and it look like it will cost me 169 apeace for 18 guage with another 112 for shipping. I can get some thinner one locally for 124 appeace no shipping and save a little. Just wondering if i need to spend the extra money.
April 14, 2014 at 3:07 pm #256551I would spend the extra money to get the heavier ones. I wouldn’t want to do the pan replacement job twice.
April 14, 2014 at 8:03 pm #256552I’ll second that.
