Home › Forums › General Discussion › Dwell Meter
- This topic has 4 replies, 4 voices, and was last updated 14 years ago by
Scott A Chynoweth.
February 8, 2012 at 8:15 am #233964
Hello everybody.
This is a long shot,but I’ve exhausted my resources.
I am looking for a copy of an instruction manual for a Sears engine analyzer model number 161.216300.Hopefully someone here has /or knows someone that has this unit.I will pay a reasonable fee for a copy.
This is a older unit with the conection/test wires conected to the unit.The only manual I can find online is for a newer redisigned unit wereas the test leads plug in. Thanks
February 8, 2012 at 8:18 am #249000Did you call Sears?
February 8, 2012 at 10:03 am #249001Here you go oldbuzz…..
Click here:
http://www.managemylife.com/mmh/lis_pdf/OWNM/1006230L.pdf
You can read it online, print it and save a copy to your pc.
PMOSSBERG40947.5527083333
February 8, 2012 at 10:48 am #249002I use the same analyzer except the newer (?) 161.214230 with plug in removable wires. I expect that you are good to go with the link that Paul sent, if not, I can copy mine for you.
February 8, 2012 at 3:00 pm #249003Thanks a bunch guys.I spent several hours and all I could find was the newer model with the plug in leads.
Used that info,(,its all basic ,hot ,ground,and pionts lead )and tried the unit out.Well is seems to pick up a signal,but I feel with age and improper storage for what is a delicate piece of equipment It does not function poperly.
A few bucks shot on an ebay purchase no big deal,Still will look good on a shelf display.
Over 30 years wrenching on cars and never owned a dwell meter.Used to borrow my uncles.Wel as ignition sytems have changed he threw is out a few years ago.
Thanks for the help guys,I knew I could get an answer hear.I just will have to buy a new unit.
Consider this issue solved.
