E-Brake & Shifter swap
Home Forums General Discussion E-Brake & Shifter swap
  • #232413
    samyer
    @samyer
    I remember seeing an article somewhere on how to move the e-brake back between the seats with stick in front towards the front of the car.  On my MiGi the ebrake is clear up under the dash in front of the stick and it is a pain.   Can anyone point me to a link?
    Thanks
    #237441
    Larry Murphy
    @larry-murphy
    Hi every one, I had the ebrake problem but my car has a one piece seat bottom so I coud not move the ebrake handle behind the shifter.I cut a v shaped section out of the handle,then bent it up  and welded it back together, also I bent and shortened the release rod to match .Now the is at a 30 degree angle to the tunnel when completely down. Not a perfect solution but much better then it was.Hope this helps somebody. I am new at computers and forums,Hope I am replying at the right place.                                        Larry Murphy
    #237442
    Larry – you did good! Yes you replied to the right place.
    Samyer…Larry’s approach is the one that Classic Roadsters included in their assembly manual. Classic Roadsters Duchess has a bench seat, so this was really the only approach they could take. It’s relatively easy and does get the handle up where you can more easily reach it.
    #237443
    Pat Dwyer
    @fareoh
    Hi,
    Any chance someone that has done the cut could shoot me a picture of the completed project?
    Thanks,
    Pat
    fareoh@gmail.com
